Old 08-24-2015, 11:10 PM   #1
willem445
willem445's Avatar
Thoughts on spark plugs fowling?
So my truck runs really good for quite a while but every once in a while it starts running like crap. Usually either replacing the plugs or cleaning them up with a wire brush fixes it. This is happened 3-4 times now and I have barely put any miles on it. Just driving it around the farm every once in a while when I go home. Any thoughts on what would cause this? The last time it happened it ran great the day before and the next day it sounded like a cylinder was missing. I replaced the plugs and wires and it ran great again. Im using the AC Delco R45TS plugs each time. Would a different plug make a difference?
The plugs are all gaped correctly and there is no physical damage to them. Just a blackish coating on them. To me they look more carbon fouled than oil fouled. I dont have any pictures at the moment but I will be going home friday if pictures are needed. I checked compression a while back and the results can be seen below.
willem445 is offline   Reply With Quote
Old 08-25-2015, 12:27 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: Thoughts on spark plugs fowling?
Fluffy black carbon fouling causes misfiring. It means you are running too rich.
Delco R45T or R45TS are the correct heat range plug to be running.
The choke might not be opening all the way or the carb is malfunctioning from crud causing it to dump in more fuel than it should.
Your compression numbers aren't far apart. They are a little low tho.
Compression ratio vs compression gauge PSI on a 350 Smallblock
8:1~8.5:1 140-170 psi
8.5:1~9.5:1 170-210 psi
9.5:1~11.5:1 210-275 psi
11.5:1 & higher 250+ psi depending on cam and other variables
Your cylinder #s are not correct on your sketch.
One head is Even # Cylinders and the other is ODD #.
Rear of engine (to the firewall)
8<--->7
6<--->5
4<--->3
2<--->1
Front of engine (to the radiator)
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 08-25-2015, 07:35 AM   #3
Dead Parrot
If the only running around is on the farm, it is likely it isn't getting warm enough to fully open the choke and never recovers from the way rich condition the choke causes. Use it to run an errand to the co-op once in a while and your problem may go away. It takes these trucks 5-10 miles to get fully warmed up.
If it isn't going to leave the farm much, might try running a hotter plug.
Dead Parrot is offline   Reply With Quote
Old 08-25-2015, 08:13 AM   #4
homemade87
Does it smoke out the exhaust when you first start it cold . If it does you may also be getting oil from the valve seals and adding to the problem .
homemade87 is offline   Reply With Quote
Old 08-25-2015, 08:57 AM   #5
willem445
willem445's Avatar
This make sense. I have been working on it alot so its mainly been starting it up for short periods of time and it really hasnt gotten to warm up fully. I am in the process of making it street legal so hopefully longer trips will be a possibility soon.
Old 08-25-2015, 09:18 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
If the choke is vac/operated a vac leak would/could leave it on.
I've had to tie off some,rough to start, but sometimes can help sort it out
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-25-2015, 08:56 AM   #7
willem445
willem445's Avatar
8<--->7
6<--->5
4<--->3
2<--->1
Thanks for the reply. I do understand the firing order of cylinders, I just labeled the cylinders and spark plug wires in consecutive order for ease.
