![]() Join Date: Feb 2014
Not mine CL find 16" 6 lug steel wheels with clips
I was searching CL and found 5 16" factory steel wheels with clips. Listed for $125. In Omaha CL. Contact # (402)650-6567. Are these desirable? These aren't mine.
Posted via Mobile Device |
![]() ![]() Join Date: Apr 2012
Re: Not mine CL find 16" 6 lug steel wheels with clips
Are they 6 clip or 3 clip ? Big difference , could be 50s truck VS 3 clip 58-63
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
I normally hang in the 67-72 section. I know many are looking for 16" rims. I called the gentlemen. He was very nice. He said he took them off a 56 chevy truck. 3 are good, 2 have some rot. they are 6 clip rims. Could you please explain to me the significance of 3 vs 6 clips. Bruce
The difference is they are more common and most that I've had or seen are 16x4 or 4 1/2wide . NAPCO 58-59 guys want and 60-63 guys want the 16x5 3 clip wheels . Still good wheels to a 57 on down group but not sure the value is as good unless for some reason they are 5 inch wide between the beads . Hope this helps. Jon
Much appreciated information. Thank you, Bruce
