Old 08-29-2015, 10:34 AM   #1
fartblossom
fartblossom's Avatar
any tips on removing old rubber based stake pocket tie downs?
This kind?
There is no "pulling" them back out. Rubber is old and expanded.
fartblossom is offline   Reply With Quote
Old 08-29-2015, 12:21 PM   #2
michael bustamante
michael bustamante's Avatar
Re: any tips on removing old rubber based stake pocket tie downs?
maybe a comealong and a low tree branch? or a hook in the ceiling of the garage?
1967custom
michael bustamante is offline   Reply With Quote
Old 08-29-2015, 12:52 PM   #3
sboris
sboris's Avatar
I would squirt some dish soap all around the edges and maybe clamp some vise grips? or similar to it and wiggle the piss out of it to maybe loosen before the comealong..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 08-29-2015, 12:53 PM   #4
67swb72klb
67swb72klb's Avatar
Wd40
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 08-29-2015, 01:39 PM   #5
bretcopsey
Is there are nut on the bottom that can be backed off? Put a large screwdriver through the eye and a socket on the bottom. The stud will probably break if the nut doesn't come loose. Either way, that should relive the compression on the rubber and allow them to pop out.
If the rubber has hardened and is retaining its compressed shape after that, maybe cut away the expanded portion from the bottom with a sharp utility knife?
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 08-29-2015, 11:17 PM   #6
LPoole
LPoole's Avatar
Originally Posted by 67swb72klb View Post
wd40
x2 !
Better to remain silent and be thought a fool than to open your mouth and remove all doubt. - Mark Twain
LPoole is offline   Reply With Quote
Old 08-29-2015, 11:35 PM   #7
Acorn
I used a combination of the methods mentioned above.
But the easiest and quickest way I got one out was:
1. Get something that is expensive and has great sentimental value to your wife.
2. Load it in your truck
3. Use the tie downt to attach your strap.
4. Stars driving down the road. It should pop right out of there in about 20 miles or so!
Stupid things. They hold when you don't want them to, and don't hold when you want them to...
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 08-30-2015, 12:07 AM   #8
fartblossom
That's awesome Acorn. I will try that in between gasoline and gamma radiation.
Old 08-29-2015, 02:16 PM   #9
71swb4x4
71swb4x4's Avatar
I would try to screw the eye off first. If that doesn't work cut the eye off. Then the top flat chrome piece will come off. If necessary you can cut it apart with a knife at that point.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-29-2015, 03:29 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
All good advice above. I've fought the same battle, and found no easy method. Unscrew & disassemble what you can, then lubricate, wiggle, and pull. Hmmm, that doesn't sound right....
After trying everything else, you may need to drive a chisel into the rubber, twist & pull and remove broken pieces of rubber, then repeat & repeat until it's all out. A bit of elbow grease and not very elegant, but it will work. Good luck.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-29-2015, 03:48 PM   #11
lil hoodlum
lil hoodlum's Avatar
I had a few of those stupid things in my stake pockets as well. If I recall correctly, I had to use an electric drill to break one up in chunks to remove it. Another I was able to get it correctly position in the stake pocket and a legnth of cord secured to it to draw it out.
I hated those things in there.
Keith
lil hoodlum is offline   Reply With Quote
Old 08-29-2015, 06:25 PM   #12
cdowns
cdowns's Avatar
me i'd take a pot of boiling water and pour it on to loosen up the rubba
Old 08-29-2015, 11:13 PM   #13
fartblossom
Thank you all. Looks like chopping up the rubber is the best option for me. I will try the drill and chisel options first, then move on to boiling water, sulfuric acid, blow torch, gasoline, and gamma radiation.
