08-29-2015, 09:36 PM | #1 |
Rattling clutch pedal in 79 K20
I'm wondering if anyone sells the parts to rebuild my mechanical clutch pedal in my 79 K20? Mine has a bad lean to it that almost makes it hit the dimmer switch in the floor when depressed. It rattles horribly if I don't keep some kind of constant pressure on it in front or behind. A couple of years ago I bought what few parts I could from brother's to rebuild the Z-bar on the frame.
I'm wondering now if I should just cut my losses and maybe replace my whole brake/clutch pedal assembly with one from another truck. Or is it possible that I can fix mine and make the rattle go away.
97 Dodge 2500 12V NV4500... way to much to list. 79 Chevy K20 4" RC/37" GY OZ's 350/465/205.... restoration somewhere in the futue.... NEW: Project 88 Chevy R3500 3+3 / 88 V3500 3+3 combing two to make one.... |
08-29-2015, 10:00 PM | #2 |
Re: Rattling clutch pedal in 79 K20
There are plastic bushings in the pedal pivot yours have probably broken and are no longer doing there job they can be had new they are LMC same as the ones in the brake pedal
LMC part number 32-6157 it's 6.95 for bushing set there is also a sleeve that goes over the through bolt and that may be worn out as well LMC carries that also
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
08-29-2015, 10:16 PM | #3 | |
08-29-2015, 11:09 PM | #4 |
I can't say for sure I replaced bushings before I did my conversion to the sm465 when the pedals were out as long as there is enough room to get the long bolt out it should be doable
