Old 09-01-2015, 12:38 PM   #1
AirSpeed
AirSpeed's Avatar
Is the radiator core support the same on gmc and Chevy?
I recently hit a deer with my 72 GMC K1500, it destroyed my grill, radiator core support, left fender, fender well and a few other parts. I found a front clip from a 70 C10, haven't been to look at it yet but not sure if the core support is the same, do Chevy core supports have mounts for the extra GMC headlights?
AirSpeed is offline   Reply With Quote
Old 09-01-2015, 01:08 PM   #2
AirSpeed
AirSpeed's Avatar
Re: Is the radiator core support the same on gmc and Chevy?
I'm thinking they're the same minus the welded on headlight buckets, I can get headlight buckets from Classic Parts but want to make sure there won't be any issues before I buy this front clip.
Old 09-01-2015, 01:20 PM   #3
54blackhornet
54blackhornet's Avatar
Not the same ! But with a good measuring you can drill out and swap the GMC buckets over to the Chevy core. Or turn it into a Chevy ! I did that on my 68 GMC but regretted it later on, JMO.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 09-01-2015, 01:38 PM   #4
AirSpeed
AirSpeed's Avatar
Is it just the headlight buckets? Is the sheet metal the same otherwise? Thanks!
Old 09-01-2015, 01:27 PM   #5
67ChevyRedneck
67ChevyRedneck's Avatar
You'll be wasting your money on that front clip... the 69-72 chevy fenders are different than the GMC. To have the turn signal hole you want a 68 chevy or 68-72 GMC fender.
Yes, you can weld the GMC headlight buckets onto a chevy core support.
If you only want the clip for the core support and inner fender, you should be good... just wanted to make sure you knew the outer fenders are NOT the same.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 09-01-2015, 01:51 PM   #6
AirSpeed
AirSpeed's Avatar
Thanks, I forgot about that crease. I can get the clip for $100 so I may still do it. Was looking at my parts catalogs and don't see any core supports specifically for gmc, I guess they aren't reproduced specifically for gmc, I did see headlight buckets so I suppose they sell those to convert the Chevy to a gmc support.
Old 09-01-2015, 01:47 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The fronts of the fenders are different. Where the eyebrows are bolted up has an slight crease in the metal in the 1969 and later Chevy fenders. The GMC fenders (which are 1968 only Chevy fenders) do not have the crease.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-01-2015, 01:56 PM   #8
GASoline71
GASoline71's Avatar
Classic Heartbeat sells the GMC core supports and they are about $70 more bucks than a Chevy core support. So if you can reuse your GMC headlight buckets and tack weld them to a Chevy core support, you can save a few bucks.
Gary
