Old 09-02-2015, 12:30 AM   #1
toolboxchev
3/4 ton Dana gears
So I have the standard 4.10 gears and the other thread got me thinking about gas mileage and rpms.
What other ratios can one put in to gain the most out of a 2wd truck?
toolboxchev is offline   Reply With Quote
Old 09-02-2015, 09:41 AM   #2
Taibo
Re: 3/4 ton Dana gears
I assume you have a Dana 60. There are 78 different gearsets for that diff. 3.54 or 3.73 will greatly improve mileage.
Taibo is offline   Reply With Quote
Old 09-03-2015, 12:02 AM   #3
Scottcoda
Scottcoda's Avatar
I had 4.56 in my Dana 60, went to 3.54 and have been very happy with it. You will find most people will do 3.73 if they have some horsepower to play with..Your lucky having 4.10 you wont have to change the carrier to go to a higher ratio gear.
68 GMC 2500 stepside LWB 250CI
Scottcoda is offline   Reply With Quote
Old 09-03-2015, 12:08 AM   #4
Scottcoda
Scottcoda's Avatar
also make sure you have the "standard" 4.10's.. My truck had no build sheet and I assumed I had 4.10.. when I cracked it open and went to install my 3.54 turned out I had 4.56 and had to buy a new carrier.. held me up for almost 2 weeks..
Old 09-03-2015, 12:16 AM   #5
toolboxchev
Yea Scott they are the 4.10's I am turning roughly 3200 rpm at 65mph. Thinking with a 4l60e trans with the low 3 to 1 first gear will make up the difference lost with the 3.54 rear for highway.
Now for that Horsepower thing, Hmmm? That ought to be making it happen.
Old 09-03-2015, 11:46 AM   #6
kwmech
Huh? I know of 9
kwmech is online now   Reply With Quote
Old 09-03-2015, 09:52 PM   #7
toolboxchev
Originally Posted by kwmech View Post
Huh? I know of 9
Tell me more about those other sets on a Dana 60?
Old 09-03-2015, 08:32 AM   #8
burnin oil
Unless you have one heck off a stump puller you are not going to want that high of a gear with an OD trans. Swap the tranny out then look at your RPMs. Its still early in my mind so my math may be off but it looks like the OD alone will drop you down to 2300 RPM at 65. Perfect for a mild cam or pulling a grade. That RPM should also keep you off of the stall convertor also.
burnin oil is offline   Reply With Quote
Old 09-03-2015, 08:54 AM   #9
70's luvr
I just installed a 700r4 with 4:10 gears. I'm wiring up the lockup switch but will report back how it works.
70's luvr is offline   Reply With Quote
