Old 09-03-2015, 12:04 PM   #1
jmillsUT28
Distributor cap hitting firewall on 72 Blazer "Fixes"?
Hey guys I am new here. Just bought a restored 72 Blazer. Trying to work out a few small bugs. One is the distributor. It's hitting the firewall pushing it forward a little to the point it starts ticking. Have to get out push it back towards the firewall about 1/4" then it stops ticking.
This only happens when I put it in reverse and back up a incline. Motor mounts seem to be fine as the engine does not move hardly at all when I put it in drive and reverse when the brake on.
It has the HEI distributor on it right now.
What are my options to fix this? I installed a 3/16" spacer on the trans mounts but still seems to be doing the same thing.
Thanks for the help!
Jon
jmillsUT28 is offline   Reply With Quote
Old 09-03-2015, 12:10 PM   #2
cleszkie
cleszkie's Avatar
Re: Distributor cap hitting firewall on 72 Blazer "Fixes"?
An HEI distributor will be a tight fit. I had to very slightly modify my firewall to make enough room for movement. Another thought - what shape are your trasfer case mounts in? If they are 40 year old rubber units, they are probably getting flattened out. New rubber or poly mounts will raise the transfer case a little, but more importantly, it will tilt the entire driveline such that the distributor will move away from the firewall.
cleszkie is offline   Reply With Quote
Old 09-03-2015, 12:14 PM   #3
jmillsUT28
The transfer mounts are old. Look worn out. Think I will try that first as it is cheaper than the $350 option for the distributor.
Old 09-03-2015, 02:28 PM   #4
wannabefastcrf
not sure if its worth all the work but you could put a mid plate between the engine and trans and then spacers between the torque converter and flexplate. pry would allow you to space the motor forward 1/4".
fyi my HEI is very tight too, although i dont have any problems with it.
wannabefastcrf is offline   Reply With Quote
Old 09-03-2015, 02:45 PM   #5
1rippen6
I would try taking some weight off the engine cradle with an engine crane loosen the bolts to the engine cradle, motor mounts, tranny crossmember, and try and push everything forward may give you a 1/4 inch or enough.
1rippen6 is offline   Reply With Quote
Old 09-03-2015, 03:09 PM   #6
Tynee
I miss this truck.
Tynee's Avatar
Body lift? Looks like you could use the clearance in the wheel wells anyway.
Pretty blazer.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 09-03-2015, 09:31 PM   #7
asolde
asolde's Avatar
maybe change your ignition system to a pertronix? It has the stock look with the performance of a HEI system.
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 09-04-2015, 12:43 PM   #8
jmillsUT28
Thanks guys, I bought some new mounts online so will try that first. Needed to replace them anyways. If that does not work then will look into the pertronix.
Old 09-04-2015, 04:12 PM   #9
Mike C
Mike C's Avatar
I used an MSD ready to run small cap distributor in my Jimmy. I knew the HEI was going to be an issue and the MSD has been the perfect solution.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-03-2015, 09:30 PM   #10
GMC-YA68
GMC-YA68's Avatar
A big hammer
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 09-04-2015, 05:45 PM   #11
hemi43
hemi43's Avatar
5.3 !! no distributor ! LOL
hemi43 is offline   Reply With Quote
Old 09-07-2015, 07:02 PM   #12
Blazerowner
Blazerowner's Avatar
I have an msd e-curve in mine. Has plenty of room.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 09-07-2015, 07:21 PM   #13
Phildeez
Phildeez's Avatar
Could it be worn out body mounts?
Phildeez is offline   Reply With Quote
Old 09-10-2015, 08:33 AM   #14
jmillsUT28
Well I installed new transfer and trans mounts but did not fix the problem. Thinking I will just give in and install a MSD.
Old 09-10-2015, 01:03 PM   #15
richard2717
Equal opportunity joke ofender
richard2717's Avatar
My 72 was giving me a fit with the old points distributor. It came with a 307 and motor mounts are in the rear frame holes. I slid old points setup out and slid the large cap HEI setup right in with no issues. I still have room to get my hand between cap and firewall with no mods.
I wonder if the body has been undone on the Blazer and may be shifted forward on the mounts a touch or the mounts are loose enough to cause enough flex to push on the cap.
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 09-10-2015, 04:47 PM   #16
4oldcars
4oldcars's Avatar
I think ya'all are makin this tough. Move the motor mounts to the front set of holes in the frame rail.
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 09-10-2015, 10:03 PM   #17
71swb4x4
71swb4x4's Avatar
Before reading anything anyone else typed I was going to suggest body mounts, looks like you are already working on that.
He has a 4wd; that would require modification to the front drive shaft for sure, probably the rear drive shaft, 4x4 shifter needs to move in the cab, and the engine oil pan may hit the differential during suspension travel. The oil pan vs front differential is the reason 4x4's use the back mounting holes.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-16-2015, 04:57 PM   #18
jmillsUT28
Hey guys I tried the mounts but they did not fix the problem so I just replaced the distributor and now have a 1/4" space and it does not hit the firewall. Nice not having to worry about it hitting anymore. Thanks for all of the help!
Old 09-16-2015, 06:32 PM   #19
71swb4x4
71swb4x4's Avatar
1/4" is about right. That's what I had on mine. It's definitely a close fit.
Old 09-19-2015, 06:24 PM   #20
Blazerowner
Wouldn't moving the engine forward require different driveline lengths? I've seen people move the engine forward to put in a 700r4 and it leaves the transfer case in the same spot.
Kirk
Old 09-19-2015, 09:22 PM   #21
jayoldschool
Moderator
Use the small cap HEI from the Camaro/Caprice/truck. Normal size cap, external coil.
Just google "small cap HEI"
jayoldschool is offline   Reply With Quote
Old 09-22-2015, 01:29 PM   #22
GMaholic
GMaholic's Avatar
Accel Point Eliminator Kit #2010, Summitt Racing, $$60.97 15 minute installation. new coil, $#40000011 $33.97
GMaholic is offline   Reply With Quote
Old 09-22-2015, 01:43 PM   #23
michael bustamante
michael bustamante's Avatar
what about the hei with an external coil? that cap is alot smaller. on the 88-98 engines i think?
1967custom
michael bustamante is offline   Reply With Quote
Old 09-22-2015, 04:29 PM   #24
jayoldschool
Moderator
Exactly what I said...
