09-06-2015, 02:29 PM | #1 |
radiator upgrade
hi i am running a stock radiator in my 64 c10 and it runs a bit hot so i am wondering what is the best up grade? is there anything that will go straight in with not to much hassle
09-06-2015, 05:18 PM | #2 |
Re: radiator upgrade
A good aluminum 2 core will cool better. Champion has alot of nice ones available.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
09-06-2015, 06:23 PM | #3 |
I would want to know why its overheating! Timing, carb adjustment, clogged radiator fins, bad water pump, thermostat etc??? If it is the radiator then is it leaking, clogged fins???
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
09-06-2015, 11:29 PM | #4 |
60-66 Nut
What engine is in your truck? Does it have the small I6 radiator or the larger V8/292 radiator? Do you have a fan shroud?
09-07-2015, 01:07 AM | #5 |
09-07-2015, 10:09 AM | #6 |
Who Me?
Check out my radiator swap. Im running a 160* stat and it never moves from that temp not matter what im hauling or how fast im going.
http://67-72chevytrucks.com/vboard/s...=508507&page=4
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
09-07-2015, 10:46 AM | #7 |
Depending on your needs, views and who you want to support, or not
Steve Lang of Langeys Hotrod Shop (on FB) mobile 07836 244483 may be able to source what you need once you identify what you need. He brings stuff into the UK at Dollar for Pound including the VAT. Hope that helps.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
09-07-2015, 01:34 PM | #8 | |
10-01-2015, 07:26 PM | #9 |
I just installed a Champion 3-core in my '65 K10. It dropped right in with no drama.
The shroud was fabricated by the PO, and while it doesn't cover everything, I wasn't having overheating problems before (I sprung a small leak, and since this isn't a restoration, a chose a new rad over having the old one fixed. Look for the old in the Classified soon) |
09-07-2015, 01:06 PM | #10 | |
09-07-2015, 11:05 AM | #11 |
+1 on the champion
09-07-2015, 11:48 AM | #12 |
I just took my original radiator to a reputable repair shop and it was close to 400 bucks for the core/rebuild w/ powerglide. After research looks like Champion is the top dog. Good luck!
HCL |
09-07-2015, 12:27 PM | #13 |
I got my 3 row auto trans champion for 209.00 to my door...ebay
10-02-2015, 04:42 AM | #14 |
read my thread I posted Monday......this radiator perfect fit quick free shipping...under $150 and looks great installed.....with warranty.
http://67-72chevytrucks.com/vboard/s...d.php?t=683738 |
10-02-2015, 06:19 AM | #15 |
Iceman....I just noticed your in England...I am assuming there will be a shipping charge to your location.
I was born in Barry Island Wales...seems we have a bit in common |
10-02-2015, 01:13 PM | #16 |
hey man im in England, i have been in touch champion radiators and they have said a 2 row is what i will need so think im gonna go for that
10-02-2015, 01:35 PM | #17 |
Gotcha...good luck
The one i showed you was a 2 row as well......as long as it works all good!! |
10-02-2015, 02:49 PM | #18 | |
I looked at several, including Champion 3 and 4 row. I ended up buying this http://www.ebay.com/itm/1963-64-65-6...item2a4ac06a83 It's just $10 more than the 2 row Champion with smaller tubing and some say it's as good or better than the 3 rows with smaller tubing. I haven't received it yet, but I liked the sellers return policy so I went with it. It's just something else to consider. If anyone knows more about the 2 row radiators with 1" tubing, please comment. |
10-02-2015, 03:35 PM | #19 | |
Champion 2 core uses .75" tubes and their 3 and 4 core's use .63" tubes. Champion also sells American Eagle radiators (the one you bought from ebay), which their 2 and 3 row/core radiators use 1" tubes. Griffin uses big 1.25" tubes in many of their radiators and so does my Entropy. This is why sometimes a 2 row radiator can be better than a 3 or 4 row with smaller tubes. IMO, the 2 row radiator you bought with 1" tubes is a better choice than the Champion 2 row with .75" tubes. |
10-02-2015, 04:32 PM | #20 | |
How do you think the Patriot 2 row would compare to the Champion 3 row? I was under the impression that they would be very close. |
10-02-2015, 04:50 PM | #21 |
Do you have a link to the Patriot radiator? I never heard of them. Google just comes up with radiators for the patriot jeep.
If it has 1" tubes and has quality core and tanks, then it should be comparable to the Champion 3 row. |
10-02-2015, 05:14 PM | #22 | |
Its an AE284 - AE stands for American Eagle Champion's standard 2 row for our trucks is an EC284 - EC for Economy Here is my radiator at Jeggs. Click on Overview. Notice they call it a Champion http://www.jegs.com/i/Champion-Cooli...AE284/10002/-1 Here is the Champion 2 row at Jeggs. Again, click Overview http://www.jegs.com/i/Champion-Cooli...EC284/10002/-1 I didn't see a lot of info but here is the site you wanted http://www.americaneagleradiator.com/ Here is some math comparing the 3 core Champion to the 2 core Patriot, from another forum. I didn't check it but here it is. 3 rows wide x .63� tubes x 2 (cuz rad tubes have 2 sides�top and bottom) x 42 rows tall x 23� wide core = 3651.5 square inches of cooling surface area. 2 rows x 1� tubes x 2 x 42 rows x 23� core = 3864 square inches of cooling surface area. Thanks Last edited by jason999; 10-02-2015 at 05:22 PM. |
10-03-2015, 01:13 PM | #23 | |
10-03-2015, 06:27 PM | #24 |
10-03-2015, 06:40 PM | #25 | |
I shopped and researched for a while. The seller I used offered to pay return shipping on returns for any reason so I thought that the AE would be worth a look. |
