09-06-2015, 11:31 PM | #1 |
Does this tank float look ok?
My truck has been in dry indoor storage since I parked it around 1991. Took the tank out to start fixing the floor and decided to dump the gallon or so of gas still in the tank. I was very surprised when I saw what happened to the float over all those years. |
09-07-2015, 02:17 AM | #2 |
Re: Does this tank float look ok?
Wow, ethanol?
09-07-2015, 08:00 AM | #3 |
I don't know. I think the ethanol thing is a myth though.
09-07-2015, 11:30 AM | #4 |
It looks fine, put it back in.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
09-07-2015, 12:09 PM | #5 |
Moderator
Most states weren't putting ethanol in fuel in 91. That's simply from condensation in the tank accumulating, then rusting out the float.
09-07-2015, 12:09 PM | #6 |
A little epoxy and it should be fine
09-07-2015, 07:40 PM | #7 |
09-07-2015, 12:11 PM | #8 |
That scares me for all of the ones I have laying around that I'll use some day or unfinished projects that I can't work on due to other things. Jim
09-07-2015, 12:17 PM | #9 |
It doesn't matter if it looks okay, only if it functions okay. You don't see it when it's in the tank anyhow!
09-07-2015, 12:49 PM | #10 |
http://www.summitracing.com/parts/omx-1772901/overview/
I put one of these in my 72 a couple months back. Even if your float did look ok they develop holes and will fill up with fuel. I would replace it with a factory type brass float or one of the cheap plastic ones in the link. |
09-07-2015, 03:03 PM | #11 |
no wonder half the fuel gauges I've ever had don't work! thx for sharing the link on the jepe float bluek5, I saved that for future ref! I've got two not working right now.
09-07-2015, 03:17 PM | #12 |
OMG! those are made of brass or copper aren't they? I think you have a wild animal in your tank ! I wouldn't think they be so prone to corrosive liquids!
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
09-07-2015, 08:18 PM | #13 |
ok I was not expecting that... That is funny.
09-07-2015, 08:25 PM | #14 |
I don't think it can be considered a float anymore!
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
09-07-2015, 08:44 PM | #15 |
laying low
Nah, it's one of those cheap imports right?
09-07-2015, 08:53 PM | #16 |
Looks like water/moisture corrosion. If you have a project lying around with fuel for that long, you may see tanks going bad also.
Bill |
09-07-2015, 09:10 PM | #17 |
09-07-2015, 09:32 PM | #18 |
laying low
It was only a joke.
But I have never seen a brass float eaten away like that. What does the rest of the fuel system look like?
09-07-2015, 10:33 PM | #19 |
09-07-2015, 08:54 PM | #20 |
That's the special bevel modification circle track racers had to make, since they're almost continually in a left hand turn. The Float was bevelled to read the fuel that was forced to the passenger side of the tank by centrifugal motion.
When you're turning left, it will all read OK.
09-07-2015, 10:06 PM | #21 |
Looks like it fits somewhere around the dump.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-07-2015, 10:28 PM | #22 |
Roadtrip!
Doesn't look too bad, a little spray foam will fix er up...
Here is mine from my 67 i recently pulled.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
