Old 09-07-2015, 01:29 PM   #1
1960chevypanel
Dual master cylinder fluid?
Anyone using anything special in their dual master/clutch cylinders? Just went to top mine off and realized I never gave it a second thought before... What's the best fluid to use?
1960chevypanel is offline   Reply With Quote
Old 09-07-2015, 01:47 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Dual master cylinder fluid?
Dot 3 brake fluid.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-07-2015, 04:56 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
Second that on DOT 3.
Old 09-09-2015, 01:06 PM   #4
61K10
61K10's Avatar
the only difference between dot 3 & 4 is 4 has a higher boiling point.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-09-2015, 02:37 PM   #5
1960chevypanel
Yeah I remember reading a debate about this a few years ago, but I couldn't find my way back to the thread. Someone was arguing for using Dot 5 fluid but I didn't recall the reason. Higher temp makes sense. This is a reg duty truck so I'll stay with Dot 3. Thanks
Old 09-10-2015, 12:29 PM   #6
Keith Seymore
I would not recommend Dot 5, which is silicone based.
a) Silicone fluid does not mix with conventional fluids, so you have to flush the whole thing out.
b) General Motors would recommend that you rebuild, replacing any seals AND HOSES that had been in contact with the previous conventional fluid
c) I have had bad experiences with Dot 5 (failed master cylinders on a regular basis). Going back to Dot 3 eliminated those problems.
K
1979-1986
1986 - 2019
Old 09-10-2015, 10:58 AM   #7
60-66
60-66's Avatar
a good read http://www.gomog.com/allmorgan/brakefluids.html
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
