adding tach
Has anyone tried adding an aftermarket tach into the 67-72 dash cluster? Something that looks like oem but cheaper?
Re: adding tach
I put one in years ago. It isn't very close to stock but it was cheap and still works.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Re: adding tach
If you do a search, there are several threads about this. Also using a factory tach from a third-generation Camaro.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
![]() Join Date: Oct 2009
Re: adding tach
Ok, I'll be the nay sayer - personal opinion only, but I've yet to see an inserted aftermarket tach that I didn't think would look better just attached to the column as intended. And since there is nothing in the opening behind it, it's not blocking anything. Again, my 2 cents only, many have done what you're asking and it turned out fine - but I always thought aftermarket tachs looked better installed as they were designed not shoved into an almost exactly correct sized hole in the dash.
Re: adding tach
Years ago I had a couple trucks where guys had stuck a sunpro chrome tach in the center hole of the cluster. It fit, but sure wasnt close to looking stock. Used cluster sets come up for a few hundred bucks..I would just save my pennies and wait for a stock one
"You can take the man out of PA, but you can't take PA out of the man" |
Re: adding tach
The PO of my truck had added an aftermarket tach as well as oil pressure and water temp gauges. I hated the look and swapped in an OEM tach cluster I found at Carlisle last year. By the time I sold the old gauges and cluster the cost was negligible.
