new to the forum need help
Hi everyone names Jose i owe a 60c10 bought as project just finish some with the bodywork bout to install the engine but didnt come. With no engine frame mounts purchase some 67-73 but not sure which hole to use or if i have to drill new since previous owners drilled to many holes eny input i will surely appreciated engine going in is a 350
![]() Join Date: Sep 2006
Re: new to the forum need help
I think you need to get those fixed. And start from scratch.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
60-66 Nut
I agree that welding up all those holes an grinding smooth would be the best place to start. As for the position of the '67-'72 small block engine mount brackets, that will be determined partly by the trans being used. If you are keeping the manual trans along with the crossmember mounted bellhousing, that will determine the location of the engine. If you are going with an auto trans, you want the engine as far back as possible for weight distribution but still have firewall clearance for the distributor and valve covers.
![]() Join Date: Aug 2004
x3
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
YEP weld'r up
#6 | |
![]() Quote:
Good luck with your project and feel free to enjoy many already-solved--and already written solutions to--problems you are likely to run into. Also, any new problems can often be solved by the vast knowledge of the members here. *I seldom have to call up local friendly mechanics and waste their time. On the contrary, I can often offer them workable solutions to some of their problems. Sam |
Thanks ill start welding them up today... and im going with a automatic tranny
60-66 Nut
I assume you are fabbing your own trans crossmember? Just be sure to get your trans output shaft parallel to the pinion.
