09-18-2015, 09:12 PM | #1 |
Trailing Arm Bushing OEM style replacement help
I just used a ball joint press to get the bushing out and in the end the sleeve thats part of the bushing is still in the arm. I could go with the poly but I was hoping to use the OEM style like this...
http://www.classicparts.com/1960-72-.../#.Vfy1C53BzRY Before I start trying to pry the sleeve out, what should I do to get it out and for the other arm...what was the right way to get the whole thing out? |
09-20-2015, 12:45 AM | #2 |
Re: Trailing Arm Bushing OEM style replacement help
Ended up doing the drill out of the rubber and using a ball joint press to pop out the inner sleeve the bolt slips through. After doing that I took a sawzall and placed the blade in the remaining sleeve and cut it just enough without cutting the trailing arm. Then I took a hammer and used the claw side and beat the heck out of the sleeve from the side, so it caved in. Then I slid out the sleeve. Now its ready for paint.
09-21-2015, 07:47 PM | #3 |
Bingo. Press the bushing out, score the shell, and cave it in on itself.
09-22-2015, 11:04 AM | #4 |
Once the paint cures up well enough and I have the replacement bushings, will I need a press to install? I read that someone put the bushings in the fridge to get the metal to contract and added the grease and it tapped in -- hopefully not banged in.
09-22-2015, 11:42 AM | #5 |
The OEM style will go right in except for the last 3/8 of an inch. I used the metal shell from the old one and turned it upside down, flange to flange. A couple whacks with a hammer and went right in. You can also use a socket if you have one big enough. Goes in a lot easier than they come out.
09-23-2015, 01:12 AM | #6 | ||
