Old 09-28-2015, 10:45 PM   #1
juddss
My 1970 suburban shifter is having trouble shifting back to park.
Anyone else have a problem putting shifter back into park. I lubed the shifter linkages under the hood and it doesn't seem any better. It seems like the pivot point inside the column up high by the shift lever is binding. Any ideas would be appreciated.
juddss is offline   Reply With Quote
Old 09-28-2015, 11:41 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: My 1970 suburban shifter is having trouble shifting back to park.
Spray some penetrating oil into the column where the shift lever goes in. Use the small tube and insert it between the lever and shift collar as much as you can. Then push the lever down toward the dash and pull it back up toward you a few times. This usually loosens it up and improves shifting into reverse and park. The lever has to be pulled back toward you to shift it into park. Let us know if that works....
LockDoc
Leon
Old 09-28-2015, 11:44 PM   #3
juddss
Yeah the leaver isn't pulling back towards me very well. Ill try it at work tomorrow and see how it works.
Old 10-03-2015, 08:14 AM   #4
juddss
Yup, this worked. I sprayed lubricant behind the pivot point of the shift lever and now it's so easy to shift! I am so happy not yo be fighting to shift gears anymore. Thanks!
Old 10-03-2015, 08:11 PM   #5
LockDoc
LockDoc's Avatar
No problem. Glad the redneck repair worked for you, I have used it a lot of times...
LockDoc
Leon
Old 10-06-2015, 08:01 PM   #6
Average Joe
Average Joe's Avatar
Funny, I was having the same issues with mine. Thanx to Leon, OP, and WD40 no more problem. Thanks guys!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
