![]() Join Date: May 2010
Turn signal switch plug question (1966 C20)
I have a 1966 C20 with a Th400 column. I ordered a turn signal switch replacement but when it came it has a curved plug. My plug is flat. After checking five different vendors sites they all of them show the curved plug. I'm not sure if mine has been switched at one time or another or?
Mine is the top photo. The plug I received is the bottom one. ![]() ![]()
It only has original paint once |
![]() Join Date: Jul 2007
Re: Turn signal switch plug question (1966 C20)
Usually later model (73) and up used a flat plug. Most replacements for early trucks would give you a curved adapter that fit on the straight connector. I have not seen a straight connector on an early turn signal switch.
The top photo is not original to the truck, somebody did some rewiring work. The bottom is the original correct multi-plug.
#4 | |
