09-13-2003, 12:07 AM | #1 |
Cantankerous Geezer
Greasing control arm shafts
I discovered today that when my son greased my new front end, he didn't get grease through the lower control arm shafts. I was able to get one side greased by blocking the frame and working the control arm up and down with a jack, but I couldn't get grease through the shaft on the other side. I had enough pressure that grease was oozing out of the joints on the filler tube, but it wouldn't go through the shaft.
My thought is to back the shaft nut almost off, then pump grease in and screw the nut back down, hoping this would push the grease through the threads on the shaft.
Fred There is no such thing as too much cam...just not enough engine. |
09-13-2003, 12:26 AM | #2 |
Sounds like a good plan to me. BTW I do have a bunch of Corvair radiators for sale. I only have 62 of them, not the 63 that you need. Oh well, better luck next time.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
09-13-2003, 08:16 AM | #3 |
Watch out for your cornhole !
It's getting pretty hard to find a QUALITY Corvair radiator. I have modified VW Bug radiators to fit, when I couldn't find a Corvair one. Seems like the German car parts are much easier to find nowdays.
09-13-2003, 08:34 AM | #4 |
F.A.S.T. president
I've made Corvair radiators in the past from PVC tubing, just have to remember to buy the hot water PVC. I find the modifing the clutch fan to fit the VW radiator too much work. Just my $.02
09-13-2003, 02:53 PM | #5 |
That shaft cap is on with around 200ft lbs. I would be very carfull you don't back it out of the arm hole.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
