Old 10-04-2015, 11:59 PM   #1
JacobSchni
JacobSchni's Avatar
Building a 454?
Ive been tossing around the idea of building a big block, not sure where to start. Im looking to get over 500hp on pump gas. Thinking of a 468. Looking around for blocks. Any reccomendations? Any advice?
1983 Scottsdale K10 496 /t400 fmvb /208 /D60 and 14ff with Locker /35x12.5x15 mt baja mtz
680hp/720ftlbs of NA fun
JacobSchni is offline   Reply With Quote
Old 10-05-2015, 02:06 AM   #2
andrewmp6
Re: Building a 454?
This might help you out some http://www.superchevy.com/how-to/pro...g-block-build/ But i would think hard about a cummins swap so you can still pass a gas station if you want to drive your truck a lot.
Old 10-05-2015, 08:09 AM   #3
birdrx7tt
Re: Building a 454?
If your building a big block you really should consider a stroker crank you can build a 496 for about the same price as a regular rebuild.
birdrx7tt is offline   Reply With Quote
Old 10-05-2015, 10:21 AM   #4
pistonbroke800
pistonbroke800's Avatar
Re: Building a 454?
I built a 496 for my short box last winter and I love it. No regrets at all. If you sit down and crunch the numbers its hard not to go with a 496 when rebuilding a 454.
I used a Scat 9000 series crank KB Hyper pistons (Wish I woulda went forged so I could spray if I want down the road) .578int .578exh 232@.050 hyd roller cam and 781 heads with 2.19 1.88 valves and a little pocket porting. RPM air gap and a pro systems 4150 carb and a set of hooker headers for a chevelle. My truck hauls azz now. Biggest problem is traction. Getting caltracs and drag radials this winter so hopefully that helps.
pistonbroke800 is offline   Reply With Quote
Old 10-05-2015, 07:38 PM   #5
meatwagon83
meatwagon83's Avatar
Re: Building a 454?
What is the engines Intended use? I just built a torque motor for my dually
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 10-06-2015, 11:58 AM   #6
77BBGMC
77BBGMC's Avatar
Re: Building a 454?
I have a similar build as pistonbroke800, no major complaints.
77BBGMC is offline   Reply With Quote
