10-05-2015, 10:12 PM | #1 |
Why - only one caliper works
Ok guys in my ongoing saga to get the brakes work I am still having problems.
I can get pedal pressure - but not firm. Everything is new other than rotors and pads there was plenty of material on them. (New booster, master, lines, prop valve, stainless lines, calipers, wheel cylinders spring kit) Front right caliper will grab and hold the rotor. Front left no resistance (nothing on the rears either). I have checked for leaks, bled and re bled and re bled - no bubbles just clear fluid. I have a new CPP prop valve but there are no leaks. I am at a loss and am trying avoiding have it towed to a shop... Can it still be air in the system or is something not working right
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ Last edited by Shugalou; 10-05-2015 at 10:34 PM. |
10-05-2015, 10:16 PM | #2 |
Re: Why - only one caliper works
Something I just thought
I guess I could remove front left caliper and see if I pump if the piston moves These are remanufactured units - and they are supposed to match the rotor size (heavy duty brake option supposedly) do these units fail often? Thanks guys
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
10-06-2015, 11:12 AM | #3 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
10-05-2015, 10:35 PM | #4 |
Have to ask. Is the bleeder on the top of the caliper on the lefg side. I have seen many calipers on upside down
10-06-2015, 07:57 AM | #5 |
Yes 70 bleeders are on the top and on the correct sides - I have been doing much reading with all the problems I've been having and when I replaced the calipers I was able to avoid this mistake.
While I was in bed thinking about the problem I recalled that this caliper didn't allow the brake pad to side flush against the piston and some material needed to be ground down on the caliper to allow for proper clearance...I wonder if this could be causing the issue? I'll try to inspect later today
10-06-2015, 11:22 AM | #6 |
Thanks for the heads up Keith will do - I guess give it an inch or two clearance to see if I can get it to come out?
10-06-2015, 11:24 AM | #7 |
When I just inspected I could move the inside pad just a touch - this leads me to believe that the piston isn't coming out at - this was with the pedal pressed down and pressure built up.
10-06-2015, 02:26 PM | #8 |
Just for clarification. Did you replace the rubber hoses that go from the frame to the caliper. If not its probably collapsed internally. If you did then you probably have a bad replacement hose , caliper or something.
Good luck with it. Frank
Born and proudly residing in a Red State ! |
10-06-2015, 02:27 PM | #9 |
Thanks for the advice
however I have replaced the rubber flex lines with Russell stainless lines. I'm wondering if remanned calipers are known to fail?
10-06-2015, 03:02 PM | #10 |
Everything is known to fail. Brand new stainless steel lines, calipers, refrigerators, chainsaws...you get the point. Don't look past something just because it's new.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
10-06-2015, 03:13 PM | #11 |
Sounds more like either a bad MC or bad Prop valve.
IIRC, 68 and newer brake systems are designed so that any one failure will not cause a complete loss of stopping ability. Many years ago I put that to the test when my 68 Impala blew the left front hose. Right brake still worked. Don't remember if the rear brakes worked or not. |
10-08-2015, 02:58 PM | #12 |
Parts and more parts
Yes, that is what I was hoping to see sopmeone say.
Frank |
10-06-2015, 03:54 PM | #13 |
Parrot I have a 78 and I think with this setup if there is pressure loss in one of the chambers it will close off (pop the pin out) either the fronts or backs.
This is setup front and back larger part of the MC is for the front disks. I called CPP tech line (very helpful) and he suggested it could be a faulty caliper. He recommended swaping calipers and bleed with bleeders facing up before attaching. If I can get the other caliper working on the left side I know I have a frozen caliper.
10-06-2015, 04:40 PM | #14 |
Yeah I know everything is prone to failure...ha this brake job has been one failure after the next...I'll be checking the calipers tonight if I can.
10-06-2015, 11:40 PM | #15 |
Ok guys a bit of an update.
So I took the suspect caliper off and found that it looked like the piston was partly coming out at the top. I took a look at the brake pad and sure as **** it wasn't seating properly against the non piston side. So part of the brake pad stuck out. I took off other side and tried those pads and no luck either. So I grinded down the brake pad points hoping that would fix it. I was worried if touched caliper it would be less easy to return. Well that didn't work so I had to grind the high spots down So I get these down to a point where the pads seat properly. I'm all excited to test everything and I think to myself - if there was offset pressure due to that bad seating could it have damaged the bore or seal. So I rub my finger over it and... I'm guessing this is screwed now? I'm thinking I'll try to return it for a new reman. Pain in the ass
10-07-2015, 02:55 PM | #16 |
Just an FYI, those sections you ground down where the pad wasn't seating, are supposed to be like that. There are two small tabs on the brake pad that you need to insert into the caliper, and then that top piece that wasn't seating where you ground the caliper down should be somewhat tight going in. Instead of grinding the caliper to fit it, you should have unbent the two small tabs a little bit. Those tabs are what hold the pad tightly into the caliper, otherwise you'll get clicking on stops as the pad moves around. That pad doesn't move inside the caliper, it moves WITH the caliper, so it needs to be held tightly in place.
10-07-2015, 03:41 PM | #17 |
Foamy thanks for the heads up - Yeah I could see the purpose of the tabs so I didn't grind them off but ground the underside to see if they would fit.
I took the caliper back and got a replacement no problem and the pad fit fine. So later on tonight I will install and bleed and see if that fixes the prob
10-08-2015, 10:12 PM | #18 |
Well I already ruled out the bad caliper.
I am beginning to wonder if the master is bad if I stroked it too much ha ha. Friggen jack off faulty replacement parts
10-08-2015, 11:28 PM | #19 |
Start bleeding the whole system. Loosen the fittings at the M/C and work your way down the system. Every joint. One at a time. Slow single "pumps" per each fitting. Don't "pump them up". Any air in the system will scatter and you'll never get pedal.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
10-09-2015, 10:05 AM | #20 |
Mr Olds,
Thanks for the tip, I was pumping them up prior. I wonder if that was my prop. I will try your suggestion over this weekend and hopefully report back with some positive results.
10-13-2015, 09:01 AM | #21 |
Over the weekend I was able to build up some pressure and when the brake are applied the fronts now grab. I still don't have correct pedal and the rears aren't working...at this point I think it has to be air in the lines and adjust the rears along with the emergency brake cable.
10-13-2015, 11:47 AM | #22 |
At the body shop.
The proportioning valve is stuck.
Took mine apart, recentered the valve, gravity bled. Finally got brakes on my 73.
" That didnt make it any newer " " Dont antique the equipment " |
10-13-2015, 02:04 PM | #23 | |
K
10-13-2015, 03:11 PM | #24 |
Guys I have fluid going to the rear and have bled out the bubbles.
Am I correct with the assumption that if the valve was closed off I wouldn't have fluid coming down.
10-13-2015, 03:22 PM | #25 |
