Old 10-08-2015, 03:09 PM   #1
Waldoe
carrier bearing
Could someone tell me what is missing from the bearing? Is it in the correct location and missing a seal, or has it slipped back out of place? I have one in my other truck, but it does resemble this one.
1970 GMC Sierra Grande Custom 2500
265/70/16, th400, 502ht
Waldoe is offline   Reply With Quote
Old 10-08-2015, 04:31 PM   #2
Xeen
Xeen's Avatar
Re: carrier bearing
That carrier bearing assembly is a clam shell you can replace just the bearing without replacing the housing.
I cant tell from the picture if the bearing is bad or not.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-08-2015, 04:32 PM   #3
der Henning
Re: carrier bearing
Hello Waldo,
there is a rubber missing around the bearing.
Here´s a link which will help you!
http://67-72chevytrucks.com/vboard/s...d.php?t=656307
der Henning is offline   Reply With Quote
Old 10-08-2015, 04:42 PM   #4
Waldoe
Re: carrier bearing
Thanks. It is not loose, and no vibrations or anything. I was greasing the truck and noticed it.
Old 10-09-2015, 08:22 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
Re: carrier bearing
Looks good from here. The stub is splined all of the way to the carrier. Newer slip and stub setups are just splined inside the slip yoke.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-09-2015, 08:28 PM   #6
Waldoe
Re: carrier bearing
The gap in between the bearing and I guess a cover, shield ,is what I did not think looks normal. That cover or dust shield does not appear to move though. Thanks
Old 10-10-2015, 09:26 AM   #7
brad_man_72
the boat guy
Re: carrier bearing
The dust shield for the bearing is optional and appears to be properly secured.
Old 10-10-2015, 10:41 AM   #8
Waldoe
Re: carrier bearing
Now I understand. Thanks for clarifying that shield
Old 10-11-2015, 11:12 PM   #9
flipbr61
Re: carrier bearing
big block truck with a TH400 have these
flipbr61 is offline   Reply With Quote
Old 10-11-2015, 11:14 PM   #10
Waldoe
Re: carrier bearing
That is what is was, is. It had a 396.
Old 10-11-2015, 11:15 PM   #11
Waldoe
Re: carrier bearing
What is the reasoning behind only big blocks?
Old 10-12-2015, 10:15 AM   #12
der Henning
Re: carrier bearing
Mine with a 350 smallblock have it, too.
Old 10-12-2015, 03:00 PM   #13
tdangle
tdangle's Avatar
Re: carrier bearing
I just looked at mine this weekend also. Looks exactly the same as the picture. I couldn't detect any slop or play, but am surprised there is no way to lube it. BTW mine is a 3/4 ton 350/auto custom camper.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
