Disc Brakes?
Ok on my k5 I'm in the process of converting it to 3/4 ton I am going to be running 15x10 steel wheels I have and I know I have to shave the calipers in the front but am not sure how much? Also I would like to swap the back to disc as Well and would the diy4x brackets work with the same amount of trimming as the front i have a 14bolt ff rear
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. ![]() 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
#2 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Disc Brakes?
Before you start, slip a wheel over the studs and see how much it looks like you'll need to remove. A small amount will be okay, but I wouldn't want to take off very much material. Have you considered 16" wheels instead of 15"?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Re: Disc Brakes?
Yes I have but it was cheaper to by a set of rims than a set of tires and I don't need a higher load range tire I like how soft my 33s are they grip really well and don't seem to wear bad at all 16s are really expensive in my area rims were 280 delivered and tires would be 800 at the cheapest in my area
Re: Disc Brakes?
And thank you for your response I'm going to give it a try almost have everything ready to go back together have to do ball joints and u joints while I have it apart
