Old 10-10-2015, 02:00 PM   #1
61K10
61K10's Avatar
leaf springs rebuild
Going to do a gear change in my front Dana 44 and will be rebuilding the springs with new bushings and shackles. will have the leafs apart to clean the 50+ years of rust and dirt out.
anything special to do to them? Any special paint or coating?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-11-2015, 11:02 AM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: leaf springs rebuild
I would used frame paint or powder coat for the springs.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 10-12-2015, 12:12 AM   #3
'63GENIII
'63GENIII's Avatar
Not sure if it's related. You may have seen the spring swap that I just finished. I found a stock set of 05 ish rear springs and a "rebuilt" set of '74 rear 52" 1/2 ton springs that had been powder coated. The 52"s are the ones that I run on the front. Well I just noticed last week that the bottom leaf of one of the packs that I bought has a crack about 4-5" from the end. Not too concerned at the moment but I am keeping an eye out for another set of springs. I have no idea if the baking process of powder coating had anything to do with the crack but the next set will be painted or original rust color for me to go through. The rear springs are factory painted. If the rear springs would have cracked, I think they would have done so by now. As far as I'm concerned, I think they have passed my abuse test.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-12-2015, 12:32 PM   #4
61K10
61K10's Avatar
probably will just wire wheel them and maybe some epoxy paint. Don't think the power coat oven would heat treat the leafs? 400*
1961 chevy K10
Old 10-12-2015, 12:39 PM   #5
'63GENIII
'63GENIII's Avatar
You know, I have no idea. I would have thought that they get much hotter when they are being tempered but really I have no clue. My cracked spring could be a complete one off as well?
Chris
'63 k15 long step
