Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 10-13-2015, 07:23 PM   #1
Steve Cole
Need advice on a good battery terminal block?
Not sure if it's called that or not, but I am looking for something to attach all the extra wires to my battery. I would like something I could attach a 4 gauge, and 8 gauge bare wire, and have 2 or 3 places to connect wires with ring terminals. Also I would like one I could still use jumper cables with. Kind of like this, but with provisions for ring terminal connections.
Amazon.com: Raptor R5BT2NSN Satin Nickel Plated... Amazon.com: Raptor R5BT2NSN Satin Nickel Plated...
Any suggestions??? Thanks.
Steve Cole is offline   Reply With Quote
Old 10-15-2015, 08:44 AM   #2
biketopia
Re: Need advice on a good battery terminal block?
Why not get something like in your link, then take a 10 or 12ga wire from the small opening to an aux. fuse block similar to this Amazon.com: OLS PSZACCEPS051H 6-Way LED... Amazon.com: OLS PSZACCEPS051H 6-Way LED... I'm assuming you want to easily be able to add circuits direct to the battery. I'm doing something similar in my 03 for a bunch of my accessories I'm adding, but using a switched source to power the switches and then the battery will feed the relays direct, I also have duel terminal batteries which gives you even more options.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 10-20-2015, 03:36 PM   #3
Steve Cole
Thanks for the advice Biketopia, most of what I am trying to connect is already fused so I don't know about having two fuses in the same circuit, especially when what I am trying to add has a much higher fuse rating than the add on fuse box fuses do.
Old 10-21-2015, 07:45 AM   #4
Galdo76
Galdo76's Avatar
I used these in my setup:
Amazon.com: Rockford Fosgate Positive/Negative... Amazon.com: Rockford Fosgate Positive/Negative...
Amazon.com: Rockford Fosgate RFD4 1/0 AWG 4 AWG... Amazon.com: Rockford Fosgate RFD4 1/0 AWG 4 AWG...
They're pricey but they are fantastic, great quality and look really good.
You can also try this website...You be a bit overwhelmed with the choices you'll have:
http://www.sonicelectronix.com/searc...terminal+block
Galdo76 is offline   Reply With Quote
Old 10-21-2015, 07:54 AM   #5
Steve Cole
Those look pretty good. It also looks like you could put a jumper cable on it if you needed to jump start your truck, which is what I was looking for. Is that correct?
Old 10-21-2015, 08:11 AM   #6
Galdo76
Galdo76's Avatar
Yes you could, the plastic cover looks to be more for cosmetics but it pops off easily enough to jump start it if needed.
One thing that I did to prevent my battery from dying is that I added a Battery Tender that are also connected to terminals. It comes with a quick disconnect plug that make it easy to keep charged and unplug.
Old 10-21-2015, 04:57 PM   #7
michael bustamante
michael bustamante's Avatar
im going to use the terminal block that comes in a 94+ chevy truck thats mounted to the firewall. theres 5 or 6 studs there to run accessories.
1967custom
michael bustamante is offline   Reply With Quote
Old 10-22-2015, 04:52 AM   #8
Galdo76
Galdo76's Avatar
Hey Michael, do you have a picture you could post? I do have another terminal block with a single stud and a few wires running to it. I've been contemplating getting it cleaned up.
Old 10-22-2015, 06:21 AM   #9
jjzepplin
jjzepplin's Avatar
I use the Raptor. I also use the multi circuit blade fuse unit but mount it inside the cab. When I connect to the Raptor I solder the wire ends. I had to file the clamp part a bit to get it to fit snug on my terminals. I just don't like how the bolt spins with one wrench. I may try a good old square head bolt. I also have deep cycle marine batteries that have the top posts and standard lugs. I connect as many negative terminals as I can to my battery to eliminate ground issues.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-22-2015, 09:18 AM   #10
Steve Cole
Hey JJ,
Do you have a pic of the Raptor? or a P/N?
Thanks, Steve
Old 10-22-2015, 10:02 PM   #11
jjzepplin
jjzepplin's Avatar
It's in your first post linky. Mine is gold though and cost about $16.99 from Auto Zone. Bought it with my free $20 with every $100 spent.
