10-14-2015, 07:49 AM | #1 |
Manual valve , TWO valve setup . ?s
So my truck is slammed with a 5.5/7.5 drop and I want to do air ride now for better ride quality. I only drive the truck a few thousand miles a summer.
I want to instal a manual valve set up . One valve for rear One valve for front Is that practical or should I run four valves ? I really like the simplicity of two. Thanks |
10-14-2015, 08:19 AM | #2 |
Re: Manual valve , TWO valve setup . ?s
It can be done, but it would be better with 4. Running only 2 valves will transfer air from one side to the other when taking turns or bumps. Also, I run slightly higher pressure on my driver side to compensate for my weight in the truck and what I suspect is a little frame sag after 45 years.
10-14-2015, 10:33 AM | #3 |
So how do the dual gauges work? How can two gauges monitor 4 valves?
Thanks |
10-14-2015, 10:36 AM | #4 |
10-14-2015, 12:05 PM | #5 |
ask and you shall have the answer. good luck.
10-17-2015, 09:56 PM | #6 |
2 valves = 1 valve to fill all 4 bags 1 valve to dump all 4
4 valves = 2 valves to fill 4 bags 2 valves to dump all 4 8 valves = independent suspension (minus solid axle) Like another member mentioned, the air will transfer from side to side/front to back if they are sharing. You will also have to make sure the lines are identical or else each bag will have different pressures (read: height) and it would be rather hard to make them equal after that. |
10-17-2015, 10:38 PM | #7 | |
10-18-2015, 12:29 AM | #8 |
And one valve for 2 wheels can make the truck not sit level its better to run 4.
10-18-2015, 02:00 PM | #9 |
one valve only does one thing.. so you need minimum 2 valves to lift and fill.. 4 valve set up is front and back, and it sucks with the air transfer that makes it sway really bad. ideal setup for a truck is 6 valves. front left fill/dump. front right fill/dump, and rear fill/dump. When you raise the truck, level the front and the rear will follow. easier and simpler than an 8 valve.
Project Roxy... Shes Bad, Low, and Blown... http://67-72chevytrucks.com/vboard/s...d.php?t=673333 |
10-18-2015, 02:08 PM | #10 |
DLOE Valves ; I believe it's like a switch, you move it up it does one thing, move it down it does another .
Can anyone clarify ? Link to the dloe valves http://dloesvalves.webstarts.com |
10-18-2015, 02:12 PM | #11 |
that is only the switch.. The switch is a 3 position momentary, most people run a single valve to do each function. (ie fill/dump) they make 3 way valves that are 2 in 1. but not the most reliable.. 1 single valve only does one function..
10-18-2015, 03:13 PM | #12 |
10-18-2015, 04:46 PM | #13 |
Manual valves do 2 functions (fill & dump) . 4 valves and 2 gauges are all you need to control all 4 corners independently
10-18-2015, 06:17 PM | #14 |
10-18-2015, 11:06 PM | #15 |
He's correct.. I missed the manual valves part.
