Roof Replacement Suggestions
Alright I have a 1972 C10 that I've been slowly fixing up and I have a question. A previous owner of my truck thought it would be a good idea to install a sunroof in the cab, so I have a large rectangle hole in the center of the cab. I bought a top of a cab, cut A and B pillars, to use to fix this one. The question I have is what would be the suggested way to replace the top of the cab.
The two main ways I've seen it done are: 1. Replace the skins using glue and welding 2. Chop A and B pillars weld back together. I realize this isn't going to be really easy. What do you think? |
Re: Roof Replacement Suggestions
I have searched and read just about every post about this. I have holes in my roof left from someone removing the cab lights and not filling the holes who knows how long ago. I also have a donor roof but, I have not done anything with it yet. I really wish there was a how to or something on this. I stopped the rain for now with some aluminum window tape. People always say to get a new cab but, my cab is great other than roof/ rockers. Plus I was able to get the donor roof for $50. No brainer.
The best advice I have seen is to measure a bunch and make sure the front and rear windows are perfect. If they are perfect then the doors will be also. I recently read through a build thread where the guy removed the inner and outer roof skin and replaced them. Looks like it would take a long time and would be really easy to mess up other things in the process. I would love if someone had how to pictures of their roof swap. |
Scott |
Haha you are the guy I was talking about! Excellent work by the way.
I would cut the old one off and put the new one back on. cut at the A pillars and middle of rear window.
Check out my thread "Meet Homer" in the projects and builds sub-forum. I cut both my cab and the donor cab off in one day and tacked in place. Next day welded completely back up. I had to go all the way down as my cab back you could walk through. Might be easier the other way, but for me, this was the way to go. Not saying it's the best, easiest, or only way to do it, just how I did it. You asked for suggestions, this is one way to skin that cat. ![]()
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#6 | |
Scott |
I wonder if you can remove the whole roof skin by removing the spot welds.If your A & B pillars are good,no need to replace them.
Check this thread out.On post #12 you can see the outer skin removed.If you can get it to that point you can use your donor cab to repair the inner roof. http://67-72chevytrucks.com/vboard/s...d.php?t=462888 |
#8 | |
Scott |
I have a customers truck at my shop right now we cut it through the a pillars and along the bottom of the back glass. In the wreck building business [that is what I do in my body shop, late model wrecks] it is call a clip cab or clip top. It is an industry norm to cut one that way and replace the damaged parts with donor pieces. I sold the customer my good clip, now i discovered on of my trucks needs one as well. Jim
Would you mind posting pictures sometime?
I have lots more of the back panel, we had to replace a strip there cause we found more rust in the cab after we had cut the top and replaced it
![]() Join Date: Sep 2010
Here is the way we did it...
Prepping the new donor roof: ![]() Donor roof welded on: ![]() ![]() ![]() In Primer: ![]() Painted and finished: ![]() Truck completed: ![]()
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
When you welded the pillars, do you have to do hundreds of tacks like when you're replacing other panels? Can you lay down short welds without worrying about warping since it's not a flat panel?
Well the A-pillar is most def thick enough to stitch weld after I tacked the roof on WiggyHD's truck then we checked the measurements then the glass then the door tops. That is the time to make adjustments. After we were both happy with everything I welded it up tight still using not tacks but stitches.
#15 |
![]() ![]() ![]() Got started a little today. |
#16 |
THe key is measure 40 times and cut once...
#17 |
triple deuce in the back whats in the front
#18 |
Just a stock 350 V-8 4v... nothing special... that 327 3-deuce goes in my other truck... both builds are in my signature...
#19 |
You guys make roof swaps look easy!
#20 |
[QUOTE=drewbert41;7342612]You guys make roof swaps look easy!
![]() They aren't real difficult if you just take your time making sure you measure properly make your cuts clean and accurate and you are any good at welding...
#21 |
I've done a couple hundred clip tops over the years I used to buy a LOT of rollovers. Jim
#22 |
I have one to do to gain clearance lamps on a cab that rusted between the cargo light and top of window. When the factory slider was installed the put caulk in the window seal that in time hardened, cracked, and let water in. Along the top of the window, lower corners, and bottom were pitted real bad, too.I was going to cut a-pillars and across under the window somewhere like the flair where the paint divider goes or lower where it's not double. Any thoughts?
#23 |
The part that would freak me out most about your decision....will the windshield fit (and seal) when I am done with the metal work?
#24 |
Again... if you measure correctly then it should seal pefectly
#25 |
![]() ![]() Join Date: Sep 2008
I agree with Hugger and Elliot. Leave the doors hanging, make cardboard templates, and measure, measure, measure. It's only metal.
