a/c clutch
can the clutch be replaced on this a/c compressor be replaced? I have changed out the clutch only on different style 0f compressor while on the vehicle.
Old member
Yes!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Oct 2005
Re: a/c clutch
It takes 2 special tools but it is easy. It can be done on the truck if you have some space in front of it. If nessesary you can remove the mounting bolts & point it upward. If the pulley brg. is noisey you can replace it at the same time.
