Old 10-17-2015, 05:56 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Anyone have the original coolant recovery tank for 71-72? Mounting issues (help!)
I bought the dealer installed kit (994230) and am running a test fit. Should mount to the radiator support, above the horn. (pictured). Link is: https://lh3.googleusercontent.com/CS...Y=w800-h600-no
First, I don't see how you can mount the bracket of this centered (width) with the radiator support. Not necessarily a problem.
Second, if the tank is too high, it hugs the top side of the radiator, and I imagine it would burn up. If it's lower, then the nipple on the bottom of the tank is intermingled with the connector for the wire harness to the horn. The horn only mounts one way.
Are the radiators wider on the big blocks? It's not quite the right radiator, and am getting another, but I don't think that's the problem. The widest part of this radiator is 34 1/2". I know the core support bushings are bad, but can't imagine that's it.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-17-2015, 06:14 PM   #2
71CHEVYSHORTBED402
Re: Anyone have the original coolant recovery tank for 71-72? Mounting issues (help!
Here's a picture of a factory installed. Bracket may be different, never confirmed. The bottle is the same.
Tony
Old 10-17-2015, 06:19 PM   #3
leddzepp
Moderator
leddzepp's Avatar
It's a tight fit. The mounting bracket will be off center slightly so you can squeeze the tank in there. It is almost flush against the radiator, the tank will not melt or crack as I have the setup on both my trucks, the one on my 72 has been on there for several years now. I mounted mine based off of pictures shown in various threads here, the one you have posted above is how I did mine.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-17-2015, 06:28 PM   #4
71CHEVYSHORTBED402
Thought to PM because I knew you had these. Won't burn up huh? Gee Golly Jeepers I hope not.
Tempting to mount a plate for it, but then I mess up the radiator support. That said, I'd be doing that anyway.....Hmmmm
Tony
Old 10-17-2015, 07:03 PM   #5
71CHEVYSHORTBED402
Hey Zep, seems the hose rubs against the horn connect, right? That or real close.
What type of hose are you using?
Sorry for all the questions. It's tempting to locate a mounting plate or two straps. Just mount those to the radiator support. The goal is original, but in this case, seems to be an improvement. Same number of bolts on the support. Even fewer if it's one plate. Plus it adds room to get the bottle in. Looks real tight, but I'm guessing.
Ever tell you great band? One of favorites to beat the drums to (another hobby). Bonham was amazing, top five at least. His tones were second to none, and time was to a Swiss watch. All Zep musicians were among the best.
Tony
Old 10-17-2015, 10:40 PM   #6
71CHEVYSHORTBED402
Course, there's nothing that says I have to use the bolt pattern on that bracket.
A stiff harness and connector to that horn doesn't help. There's not enough play either. I won't tape up the new electrical like the existing. A different connector on the horn might be an option.
Tony
Old 10-18-2015, 01:19 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Here are pics of the tank/bracket as I installed it on my 68. You are correct...the hose sits right next to the horn contact/wiring harness. It does not rub on it, but yes a very tight fit. Sorry for the crappy upside-down pic, it is dark here and my cell phone sucks...but you can see it's proximity.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-18-2015, 01:26 AM   #8
leddzepp
Moderator
leddzepp's Avatar
Here is a pic of the tank removed. I off-centered the bracket and used only one upper and one lower attaching point on the core support. It is more than sufficient to hold it in place...bailing wire could do the job, lol. Sorry again for the crappy pic, but you can see what I'm talking about.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-18-2015, 01:30 AM   #9
leddzepp
Moderator
leddzepp's Avatar
Pic showing how close the tank is to the radiator.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-18-2015, 01:39 AM   #10
71CHEVYSHORTBED402
I couldn't ask for more than that. Thanks Zep.
Tony
Old 10-18-2015, 01:55 AM   #11
leddzepp
Moderator
leddzepp's Avatar
Thanks for the Zep props Obviously my favorite band I agree all were stellar musicians, but I take a special liking to drummers in particular.
My top five list:
1. Neil Peart (perfection)
2. Buddy Rich (OG)
3. Bonzo (of course)
4. Keith Moon (insane)
5. Charlie Watts (Technically not much better than Ringo but I love the Stones and he is a "cornerstone" to the band)
The above are just my personal favorites, there are many others...Ginger Baker, Mitch Mitchell, Stewart Copeland, Lars, on and on.
Sorry for the sidetrack, hopefully my pics help out
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-18-2015, 03:41 AM   #12
71CHEVYSHORTBED402
After my original post concerning, I got into the mood and managed to bust through my bass drum head. Go figure.......It was due.
Top five drummers IMO, no particular order:
John Bonham
Neil Peart
Vinnie Colaiuta
Carter Beauford
Buddy Rich
Little story. Rich's "competition" (but not really) was a guy name Gene Krupa. He also led his own orchestra, which required another drummer. My dad had an orchestra as well, and they used the same drummer. If you're interested, this is one of the few jazz tunes pops wrote. Probably not the same drummer though, because it was a different set of music and musicians. 1956ish. It's a change of pace. http://yourlisten.com/GOULD/the-big-...ads-jazz-tunes
Tony
Old 10-18-2015, 05:01 PM   #13
54blackhornet
54blackhornet's Avatar
Your Dad's jazz piece was truly amazing, thought I was back in the 40's ! Any more you can post ?
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 10-18-2015, 05:33 PM   #14
71CHEVYSHORTBED402
Glad you like it. Reminds me of the Pink Panther Theme. He didn't write many jazz tunes. Mostly melodies. He had one jazz "swing" album, but they were his arrangements of someone else's tunes.
Here's one that has some nice jazz (have to wait for it), but the song is unremarkable beforehand and the lyrics are awful. Funny story. My dad's tune is on the A side of this 45. The 45 sold a bunch, but because of the B side. The B side was a big hit, but my dad didn't write it. Anyway, here's my dad's tune (A side), if you can bare it. https://www.youtube.com/watch?v=csSETR2L4jw
The hit (B side) is called 'Teach Me Tonight". It's obscure, but I like it. It's on Youtube.
Maybe I'll post some of the melodies he did. If you like melodies, I think you'd really like his work. Me, I'm a sucker for melodies.
Tony
Old 10-18-2015, 05:45 PM   #15
71CHEVYSHORTBED402
For the melody lover, here are three consecutive on the same track. IMO, the 2nd and 3rd are super, and bring back a lot of memories. I don't believe he wrote any of these three, just his arrangements. There's about 20 violins here. This was 1969ish, so with today's technology, you could probably get by with 4-5.
http://yourlisten.com/MYMUSICKS/medley-2
Here are a couple off his jazz album. Fletcher Henderson stuff. The drummer I mentioned above is playing.
http://yourlisten.com/MYMUSICKS/johnson-rag
http://yourlisten.com/MYMUSICKS/blue-fletcher
Pops was talented. Skips a generation. But you wouldn't find him under a truck.
Tony
Old 10-18-2015, 09:00 PM   #16
71suburban/70CST
Where did you guys find this factory accessory? If anyone has another one of these, I would be interested.
Thanks,
Justin
71suburban/70CST is offline   Reply With Quote
Old 10-19-2015, 12:09 PM   #17
71CHEVYSHORTBED402
Thanks,
Justin
Post on the parts board, maybe you'll get a hit. They aren't cheap.
Tony
