Old 10-18-2015, 03:20 PM   #1
scrappy70
scrappy70's Avatar
AC Vents
Need some help. I purchased new AC vents for the dash. Is there another part that keeps the AC vent ball from falling out the back? I have the outlet bezels but it looks like something should be on the back keeping the ball from falling out. Any takers?
scrappy70 is offline   Reply With Quote
Old 10-18-2015, 03:31 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: AC Vents
Once you install the dash part you put the ball in then there is a strip of foam that should go in it also to make the ball stay as you point it and not let it roll around inside the housing.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 10-18-2015, 04:24 PM   #3
68panelman
68panelman's Avatar
Re: AC Vents
Its actually a felt strip. I assume foam would tend to stick, or grab too much.
68panelman is offline   Reply With Quote
Old 10-18-2015, 05:50 PM   #4
Bigdav160
Bigdav160's Avatar
Re: AC Vents
I think the OP is referring to the piece that connects to the vent hose.
LMC calls it the "air outlet adapter"
They look something like this
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-19-2015, 12:15 AM   #5
scrappy70
scrappy70's Avatar
Re: AC Vents
Thanks bigdav160. I knew there was something else that connected to the hose.
Old 10-19-2015, 05:49 PM   #6
Andy4639
Old member
Andy4639's Avatar
Glad you figured it out. I was going by your original post and thought you wanted to keep the ball inside the dash vent. Not connecting the hose.
Old 10-20-2015, 01:03 AM   #7
scrappy70
scrappy70's Avatar
Re: AC Vents
No worries Andy. I have the right parts on order. Thanks.
Old 10-20-2015, 08:58 AM   #8
Andy4639
Old member
Andy4639's Avatar
Good deal!
LMC has the best pictures of anyone. May not always be best parts are price but you can't beat their pictures!
Old 10-22-2015, 05:23 PM   #9
scrappy70
scrappy70's Avatar
Re: AC Vents
Yes, I agree. They have better pictures for sure.
Old 12-11-2021, 06:38 PM   #10
Peanut74
Re: AC Vents
Got a question. What is the order of the parts going together? When I took off the hose adapter everything fell out and I don't know where to attach the felt strip.
I believe the order is:
- Dash A/C housing (Back facing up)
- Felt strip installed to the bottom
- A/C ball vent
- Install another felt strip to the bottom where the adapter changes sizes
- Assemble the hose adapter and the a/c housing into one unit
Is this right?
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
