Engine wiring question Purple and green
I pulled out my 350 motor and we built a 383 stroker. On my old started, there were 2 wires that ran down to it. I believe purple and green??? My new starter is a high torque one. It only has 1 position for a wire. So.............If i'm correct, one of those wires is the start wire that will go to the starter and the other wire is a run wire that needs keyed 12V?
let me know. Thanks
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
Re: Engine wiring question Purple and green
On my setup, only 1 wire from the harness is used with hei. The yellow wire is taped back and covered up. Purple to the solenoid, and starter connection, and that's it.
Ok, when I land the motor I will try that. If I have running issues, then I guess I will need to dig out that wire and find somewhere to put it?
Who Changed This?
![]() Join Date: Jan 2013
The yellow wire provides power to the coil through the solenoid when cranking the engine to start it. If you tie it off, you may have a lot of cranking since you won't be powering the coil. You'd have to get it spinning and let the ignition catch when you let go of the key. I get around this by using a remote solenoid from a competing automotive manufacturer to provide power while cranking.
#5 | |
x2. I have HEI, with a newer style starter. Distributor is directly wired up (red wire), purple going to starter, and the green/yellow wire is taped up.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
Thats what I did and it worked great.
Who Changed This?
I didn't say it was used on the HEI, I told him what it is for, and gave him an alternative, since that wire will be tied off.
