Co2 Tanks
I'm new to welding and want to hook up the Hobart 140 to gas. My local Craig's List has Co2 tanks for paintball guns and beer, others with no description at all, some are steel and others aluminum. Are there tanks that can and can't be used with a welder? Does the valve threading vary by intended use? What do you look for when purchasing a used tank ... or just go to the local welding supply store and bite the bullet?
Would a tank like this be appropriate for welding ... http://philadelphia.craigslist.org/tls/5244429865.html
My truck ain't dead, it just smells funny. |
![]() Join Date: Jul 2015
Re: Co2 Tanks
that would work, but if you are welding mild steel it's better to use a mix of argon/co2 pure co2 is best for welding aluminum. You could call your local supply place and see if they will take it in on trade.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
#3 | |
Re: Co2 Tanks
Cut and paste from an article on welding gasses:
Re: Co2 Tanks
buy the biggest tank you can afford or you will be filling it all the time
or running out on the weekend when the lws is closed when buying used tanks make sure it's not a rental tank or your lws may not fill it also tanks need to be pressure tested and inspected every 7 yrs, figure that in when buying an used tank
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Re: Co2 Tanks
So typically the local supply house doesn't care if I walk in with an empty Co2 or Acetylene tank and ask for C25, as long as I'm trading in an equal size tank that's inspected and not leased? Also, how do they know if a tank is leased? I know these are rookie questions, 50 years on this earth and I still don't know it all.
meowMEOWmeowMEOW
Re: Co2 Tanks
They won't fill a Fuel (left hand) tank with a Shielding/inter gas (normal thread). Thats a no-no.
Tanks are stamped with serial numbers like a VIN up on the neck and sometimes under the bottle. Most of the large gas companies will have thier names stamped along with those numbers. If you take it to a commercial welding supply, they can see if the tank is under lease (but if it is, they may create a problem for you). Smaller places might still allow you to refill a tank, but usually they'll let you trade in a tank of "dubious history" in exchange for a new tank from them, sans any of the credit checks or deposits etc. I've bought them from contractor sales and flea markets before. Very few places will actually just fill your tank outright, since its much harder for them to ascertain that you've properly maintained and transported the tank.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: Co2 Tanks
Where I'm from, any bottles under ~150 cu/ft are "owners bottles". Anything larger are leased.
There are several welding stores nearby. Sometimes they fill my bottles, sometimes they exchange. You have to be careful because sometimes they give you a bottle close to it's expiration date.
Re: Co2 Tanks
"Owner" bottles no matter the size do not have a collar with names formed into them. If the tank has a collar, a gas company owns it.
The smaller bottles are usually owned and you simply trade the empty for a full one just like it. The 100# bottles can be owned, but you will likely lose it to a trade because you need it now. Then later the gas guy forgets all about it and charges you rent. It's practically impossible to fight and win. So rule of thumb, own the small bottles, rent the big bottles.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Re: Co2 Tanks
Eraser, you made me look. My oxygen and acetylene tanks were given to me by a neighbor that was moving. the rest i purchased.
C25- no name. I had refilled at a local store recently Acetylene - no name CO2 - no name Oxygen - Airgas. This bottle I did exchange at an Airgas store Argon - Airgas. The local store has been filling my bottle but just recently changed to Praxair. They exchanged it just the other day for this bottle.
