Grandpa in the rustmobile...
Front "A" arm shafts/bushing replacement
Front control "A" arm bushing replacement..is it correct?
I replaced all the shafts on the control arms. I tightneed both sides evenly and until the big nut is flush against the control arm but I still have a gap (even on both sides) between the bushing and the a arm. I have attached a picture. Thank you. (TX firefighter/lowlife)??!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 Last edited by oldblue1968chevy; 10-22-2015 at 12:05 AM. |
Never Ending Projects
Re: Front "A" arm shafts/bushing replacement
I don't have any close up pics but it seems your outer bushing/nut is not seated all the way in the pic. Here are two different sets of arms I did and you can see there is no gap between the nut and arm.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Thanks Chevymike.
I got the big nut torqued all the way down after the picture. I'm just wondering about the rubber seal should it be up snug against the arm? Thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Not really needed. The part that seals out dirt is the area on the shaft (the area that the seal necks down to). You should be fine.
So I just discovered that my (powdercoated) mcgaughys drop spindles don't have the holes for the dust covers
![]() Do I drill into them and tap them? Or run without dust covers? Thanks ![]()
Dropped spindles typically are design not to work with dust shields. I have always run without them.
#7 | |
![]() Join Date: May 2011
![]() I think they would work if you drill and tapped the bosses on the spindle, but most people don't run them. They would probably be a good idea if you are on dirt roads allot, I can certainly see that they protect from rocks getting stuck in the pad.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
I don't mean to hijack this thread, but it seems like a good time ask this question.
What is the torque spec on that big 1 5/8" nut? I have heard numbers as high as 280 ft.lb. and as lo as 115 ft.lb.
I believe my Haynes book was like 200+ ft lbs..I'd have to look again to be sure..
