10-23-2015, 09:13 PM | #1 |
Caster Changes
Since aftermarket control arms now have the needed caster added to them can I just install the uppers at this time? What will happen if I don't replace the lowers at the same time?
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
10-24-2015, 08:42 PM | #2 |
Re: Caster Changes
I think they are adding the caster to the lowers. The order that you do them is not to important as long as you get it aligned after the change.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-26-2015, 10:04 AM | #3 |
Re: Caster Changes
The ones from CPP add caster with the upper ones. I have only swapped my uppers.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
