Old 09-14-2003, 08:00 PM   #1
wbmoore
Question Suburban body mounts
How do ?
Are the front body mounts on a Suburban cab the same as a truck ? I'm talking about the platforms that hang off the frame....are they in the same place on both truck and Suburban frames ?? What about the rear ? Does a 'burb' have 6 or eight mounts ? The reason I ask is I want to put a Suburban body on a 1-ton frame. Thanks for the input. brad moore.
1967 GMC 3500 lwb dump flatbed project
1969 GMC 2500
1979 GMC 7000 fire crew truck w/water pumps
1982 C/30 Cummins NV5600 Crew Cab project
wbmoore is offline   Reply With Quote
Old 09-14-2003, 08:09 PM   #2
Bob Chayer
The rubber mounts are different than my 3/4 pickup. They are shorter and may be spaced differently. Not sure on the number but I will be under my burb in the morning so I'll check it out. I will let you know.
Bob Chayer
71 3/4 ton 4X4 Suburban
Bob Chayer is offline   Reply With Quote
Old 09-17-2003, 09:35 AM   #3
GMCPaul
There are a total of 6 body mount positions per side on a Suburban or Panel, all 1967-72 Suburbans 1/2 ton & 3/4 ton, 2wd & 4wd and all 1967-70 Panels 1/2 ton & 3/4 ton, 2wd & 4wd use these same body mounts. These body mounts are not the same as a pickup except for the 2 at the very front on left & right side. The radiator support mounting kits are all the same whether its pickup, Suburban, Panel, Blazer, Jimmy with 2 styles available 67-68, & 69-72.
We carry all of the body mounts, if interested you can find them here
http://www.gmcpauls.com/rubber_&_weather_strip_21.htm
GMCPaul
GMCPaul is offline   Reply With Quote
Old 09-17-2003, 10:22 AM   #4
cheyenne10
cheyenne10's Avatar
thanks guys
Thanks for post and personal email.
Bob
cheyenne10 is offline   Reply With Quote
Old 11-10-2012, 05:15 PM   #5
cheyenne10
cheyenne10's Avatar
Re: Suburban body mounts
TTT for post support
Bob
