10-27-2015, 01:14 PM | #1 |
Need help with wheel offset selection
I'm installing a CPP 4 wheel disk brake kit on my '65 stepside. Of course, now I need new wheels and am about to place an order, but concerned with which offset I need.
I'm going to run a 20" x 8.5" front wheel with an offset of .3" (20 X8.5 5-127.00 7 DGMCML) The rear wheel is a 20" x 9.5" with an offset of .6" (20 X9.5 5-127.00 15 DGMCML) Front tires will be 255/40R20 Rear tires will be 285/40R2 Do these offsets sound right? Thanks for any help! |
10-27-2015, 01:31 PM | #2 |
Moderator
Re: Need help with wheel offset selection
Until you get the wheels installed it would be difficult to know exactly. However when you do you can use this chart to determine various dimensions:
http://www.thewheelsmith.net/WheelGeometry.html
10-27-2015, 04:57 PM | #3 |
That doesn't sound right to me. I have 8 inch wheels front and back and they have the standard offsets (I think 4") and they fit grate. I am running a 275 tire front and back. But I am no expert.
10-27-2015, 05:05 PM | #4 |
I'm being told that back spacing on the front should be 5.25" and 6.5" on the tears with a 10" wide wheel. Does this sound correct?
10-27-2015, 07:02 PM | #5 |
Best to measure it yourself.
Like this. http://www.hotrod.com/how-to/wheels-...heels-fitment/ You can buy a tool if you want to make it easier. Like this. http://www.summitracing.com/int/part...1201/overview/ The Percy's tool lets you simulate tire sizes too. |
11-02-2015, 06:54 PM | #6 |
I sure agree with Geezer.
Measuring, even if you have to make up a tool is a LOT cheaper than buying rims that don't work. My current el cheapo tool is made from 2 wooden yardsticks. they both have slots routed in them . I hold the vertical one against the wheel mounting flange and adjust the horizontal up to wheel/with tire diameter and then out to fender well clearance and WHAM. Don't forget to count the 1/2" of the vertical yardstick in your backspace decision. W |
11-03-2015, 10:02 AM | #7 |
Great advice guys, thank you!
I will take measurements once the brakes kit is on the truck and then will order my wheels. |
11-13-2015, 09:50 AM | #8 |
Well, I have it done! I went with the following wheels and tires with the CPP big brake kit
The wheels are 20" Rev Classic 20 x 8" front wheel with a 4.5" backspace 20 x 9.5" rear wheel with a 5.84" backspace Front tires are Nitto NT420S 255 /40 R20 Rear tires are Nitto NT420S 285 /40 R20 |
11-13-2015, 11:25 AM | #9 |
Looks like you made a good decision. Very nice.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
11-13-2015, 12:53 PM | #10 |
Registered Loser
Nice!
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
11-13-2015, 02:05 PM | #11 |
Lovely looking truck.
How much clearance is there from the outside of the rim/tyre and the inside lip of the fender? Also, how have you converted to 5 lug?
'63 C10 Longbox fleetside '94 C1500 Sierra ex-USAF beater |
