Old 10-28-2015, 11:22 PM   #1
dozerbill72
dozerbill72's Avatar
65 short bed 3/4 ton?
I found a 65 3/4 ton 4x4 with a 327 and a 4 speed that is a short wide box. Did the factory ever make this combination? The owner swears up and down that it is all original. It's in a poorly lit building and I had no flashlight the other day when I found it. If the axles have been changed how ever did it used factory u-bolts and plates for the larger rear end. I could not see any place where the frame had been cut and shortened. I also could not open the door to see the VIN because of another car beside it. I would like a little input before I go to the trouble of unearthing it.
Thanks,,,Bill
dozerbill72 is offline   Reply With Quote
Old 10-28-2015, 11:25 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: 65 short bed 3/4 ton?
You'd be best off to check the vin before making a final decision.
Old 10-29-2015, 12:21 AM   #3
Captainfab
60-66 Nut
To my knowledge GM did not make short wheelbase C/K20 trucks in the '60's, '70's or '80's. Does this truck just have a '20' emblem, or does is actually have 8 lug wheels? The 8 lug axles will bolt right up where the 6 lug axles were.
Old 10-29-2015, 04:19 PM   #4
Clyde65
Clyde65's Avatar
There were never any Short Bed 3/4 ton frames. They would have to be cut 3/4 ton or 1/2 ton frame. The frames are thicker and larger on 3/4 tons
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-29-2015, 05:01 PM   #5
padresag
not that you would see it by eye though.
½ ton 2WD: 6-1/32 x 2-1/2 x 5/32
¾ ton 2WD: 6-1/8 x 2-17/32 x 3/16
ron
padresag is offline   Reply With Quote
Old 10-29-2015, 05:45 PM   #6
dozerbill72
It has no badging on it and yes it is actually eight lug. I am going to try to look at the VIN this weekend. Thanks for the input.
