10-31-2015, 07:53 PM | #1 |
220 gauges or 160 gauges ? Air pressure
I plan to install a manual valve air setup on my c10. I want order air pressure gauges. What size gauges sound I get to monitor the pressure in the bags? 220 or 160 psi ?
Thanks |
10-31-2015, 07:59 PM | #2 |
Re: 220 gauges or 160 gauges ? Air pressure
I never had more than about 70 pounds in my front bags so I don't see the need for more than 160 for monitoring the bags. Now for tank pressure you may need the 220.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
10-31-2015, 11:27 PM | #3 |
You should never have more than 125 psi in your tanks and I don't think you will ever have more than 90 psi in the bags. 160 is plenty!!
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
11-02-2015, 10:02 AM | #4 | |
220 psi single needle gage for the tank / 160 psi dual needle gages for the bags. |
11-01-2015, 06:51 AM | #5 |
Thanks guys
11-02-2015, 10:14 AM | #6 |
Thanks , I'll be running viar 444 compressors
11-02-2015, 12:52 PM | #7 |
Those are rated at 200 psi / 3.5 CFM and 100% duty cycle @ 100 PSI (50% @ 200 PSI).
I'm using dual 444c's and a 165-200 psi pressure switch and they can fill two 3 gallon tanks tied together from 0 to 200 psi in approx 3 minutes. They will "top off" the tanks from 165 to 200 psi in about a minute and half. Just wanted to share, although I don't "need" 200 psi. |
12-29-2015, 07:28 PM | #8 |
not to hijack the thread but are you using 1/8 or 1/4 line for the gauges? Is there any pros or cons to either size?
11-02-2015, 10:38 AM | #9 |
Just because it will produce 220 psi doesn't mean you need 220 psi. I drive truck for a living. My truck runs 125psi. No airbag system I know of needs more Than that. Even my commercial compressor stops at 130 psi.
12-30-2015, 09:25 AM | #10 |
Agreed... the 160 PSI gauges will be good and usually a little easier to read since they havae less tick marks for pressure. We use 160 PSI gauges in our systems and work perfect.
http://www.azproperformance.com/Air-Gauges/ |
12-30-2015, 10:35 PM | #11 | |
Squarebody guy
It also increases your total tank volume for an increased amount of usage before having your compressors kick in to refill your tank. You don't see a lot of people running 200 PSI around here because most aren't playing with their switches a lot but some people like to use their systems for more than just laying out while parked or low in the parade procession.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress |
12-31-2015, 10:10 PM | #12 | |
Anyway, hello neighbor!
01-01-2016, 07:19 AM | #13 | |
Squarebody guy
I have a york 210 sitting on the shelf because it wouldn't fit under the hood of my toyota easy enough, which has AC and power steering. I am most likely going to run the stock engine mount compressor from the bus cummins engine I have on the dually I am building. There is no replacement for the air displacement/CFM an on-board compressor can give you. All of this still doesn't replace the fact that someone wanting slightly faster fill times would usually go with 200 PSI and/or 1/2 lines and valves regardless of fill times or CFM. How long does it take your truck to get from aired out(zero PSI for me as I lay frame and lay out every time I park) to ride height? Neighbor???? Hell yeah, we need to meet up and chit chat sometime. I haven't met any C10(C20/C30) enthusiasts in person locally yet.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress Last edited by Ghostwhite; 01-01-2016 at 07:25 AM. |
