Old 11-02-2015, 12:55 PM   #1
gmebey
Flushing Power Steering Box
I'm replacing my power steering pump and it appears that the old fluid is a mix of ATF and PS Fluid... I think.
So what is the best way to flush out the stuff in the steering box?
gmebey is offline   Reply With Quote
Old 11-02-2015, 01:13 PM   #2
EARNHARDT#3
EARNHARDT#3's Avatar
Re: Flushing Power Steering Box
Just turn it lock to lock and let it push it out. Don't worry about flushing unless you've got metal flakes in the system.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 11-02-2015, 01:17 PM   #3
Jrainman
Jrainman's Avatar
great way to get a fresh start ,just dump the old add new PS fluid then dump and run your system (turn wheels) again dump and add fresh. that should get you clean and fresh. they do also make inline PS filters ,witch is a good thing to add also.
Newer steering system (rack and pinion ) are more prone to issues from dirty fluid and due run hotter so fluid does break down ,most have filters built in to the system ,they also require changing fluid and filters at regular intervals.
Jrainman is offline   Reply With Quote
Old 11-02-2015, 01:24 PM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I use one of these... Amazon.com: OTC (2359) Oil Suction Gun: Automotive Amazon.com: OTC (2359) Oil Suction Gun: Automotive
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 11-02-2015, 02:07 PM   #5
gmebey
Earnhardt#3,
Are you saying I can do this without the engine running?
Old 11-02-2015, 02:19 PM   #6
EARNHARDT#3
Originally Posted by gmebey View Post
Earnhardt#3,
Yes. Jack the front of the truck up to make it easier.
Old 11-02-2015, 02:22 PM   #7
gmebey
That is simple! Thanks!
Old 11-04-2015, 10:28 AM   #8
gmebey
I used Earnhardt#3 suggestion and captured this....
Old 11-08-2015, 01:05 AM   #9
62LS1
62LS1's Avatar
https://www.youtube.com/watch?v=bZwrtf-BR7I
This is a good video on flushing the PS system from one of the major steering remanufacturing companies. Hopefully I copied and pasted correctly so you can see it.
Too many dreams, too little money.
62LS1 is offline   Reply With Quote
Old 11-08-2015, 11:49 AM   #10
gmebey
The link worked, and I found a nice list of fluids tested by Cardone.......
Old 11-08-2015, 03:24 PM   #11
Bigdav160
Bigdav160's Avatar
I'm pretty sure ATF was the fluid specified originally. There's no issues mixing them.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-11-2015, 12:02 PM   #12
gmebey
After referencing the service manual, which in 1970 stated (1st choice) Power Steering Fluid and (2nd) ATF…. I decided to go with PS Fluid.
The crap in the bottle appears to be a mixture if anything……PS Fluid, AFT and motor oil(?). Wow this poor truck has had some rough years!
Thanks for all the help.
