11-02-2015, 10:40 PM | #1 |
1970 gmc rearend
Would axles out of a 78 Chevy fit back in the 70 gmc rearend. Haven't ever messed with the gmc stuff and wasn't sure
11-02-2015, 11:40 PM | #2 |
Re: 1970 gmc rearend
Thats an open question, 2wd, 4wd, 1500, 2500, leaves, coils.. Chances are yes it would need different spring and shock mounts.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-04-2015, 08:25 PM | #3 |
1970 GMC 2wd SWB leaf spring rear. The plan was to take the axle shafts out of a scrap '78 2wd truck and swap them into my 1970 axle shafts in order to convert to 5 lug.
11-03-2015, 12:18 AM | #4 |
Axles or housing? The axles in a 73 up rearend are longer than either length 67-72's. 73 up Housing will "fit" with new perches & possibly shock mounts (leaf or trailing arm?).
11-03-2015, 12:56 PM | #5 |
axles will not slip in either 67-72 length housing. are you trying to switch to 5 lugs. early classic i think sells the shortened 5 lug axles. but 70 is a dual length axle year. youll have to measure the rear end before you order
1967custom |
11-03-2015, 11:16 PM | #6 |
when i put the 73 rear in my 70 leaf spring chevy the 70 6 lug axles and drums went right in and worked fine...after i converted to front discs i put 5 lugs back in....i believe 67-69 housings were narrower and axles shorter
1970 short step c10 leaf spring 454 |
