11-03-2015, 10:42 AM | #1 |
8.55@161 video C10 DIESEL
https://www.youtube.com/watch?v=iUfrR37-Olo
Had a great day at the track and ended the season with a new personal best. Made 4 passes 8.55, 8.60, 8.62, 8.63 Big thanks to my family and sponsors Wife and Kids Parents Danville Performance HSP Diesel Wagler Competition Bullseye Power Neal Chance Racing Converters Mayeda Motorsports FlexiCorps Racing Deutsch's Truck Repair
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning. 8.3@168mph 1700+ HP |
11-04-2015, 04:23 AM | #2 |
Re: 8.55@161 video C10 DIESEL
Great job!
Can I ask a question though? Why is it every or just about every single diesel powered truck runs the exhaust straight up in the air?
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
11-04-2015, 07:46 AM | #3 | |
Two, if you point it at the ground or out the side you have a chance of "smoking out the lights" witch means the beam of light that tells the timing system you are up to the line ready to race gets smoked out and can't tell when you leave. If this happens you are automatically DQ'ed and loose that race.
11-04-2015, 07:47 AM | #4 |
11-04-2015, 09:26 AM | #5 |
Awesome runs. That thing is gettin down!
NHRA Super Street 469C It only runs 10.90 at 156 mph |
11-04-2015, 07:38 PM | #6 |
Thanks for the info.
11-08-2015, 10:25 AM | #7 |
Active Member
Awesome!
11-15-2015, 08:44 PM | #8 |
What's up Brett? This is Phil Puleo, Jons brother. Your truck looks awesome and puts down some crazy numbers. Nice work!
12-17-2015, 04:14 PM | #9 | |
Your truck looks like it is coming along very nicely. Hopefully we can get together this summer and hit up some cruse nights or car shows.
12-17-2015, 06:03 PM | #10 |
12-17-2015, 03:57 PM | #11 | |
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
12-17-2015, 04:12 PM | #12 | |
I'm at a point with my truck to stay on top I need to install a sfi 25.6 cage in it or turn it back into a driver. The sfi cert. as of right now will only let us heavy guys (3601 and up) run 8.50 and slower. This winter they are coming out with a 25.6 cert. to let the heavy guys run 7.50 and slower as long as your under 5000lbs. I would love to do the 25.6 but not with this truck. I would like to find a fiberglass cab and front end so I can switch them out with what I have now. That way later down the road I can put my steel stuff back on. My grandpa gave me this truck and it mean way to much to me to cut it all up to install a cage.
12-18-2015, 11:49 AM | #13 | |
12-28-2015, 10:56 AM | #14 | |
12-28-2015, 11:00 AM | #15 |
We decided to get a baseline from my current setup to see how, where and why it makes the power it does. Recap on the setup is LLY motor with 15.5Comp Oval Race cast pistons with reliefs, SoCal 9100 Cam, Wagler Extreme heads, HSP Billet manifold and big up-pipes, HSP Triple turbo kit featuring Bullseye Power B475-96 T41.0ar double gated and fed by a pair of TCT475/87 1.0ss turbos. Uses factory clam shells fed by 3" y-bridge and a front mount air to air cooler. Fuel is 175%inj Exergy injectors fed by pair of my modded LBZ cp3's. We recorded all the data on it also so we can compare apples to apples. This is exactly how it was ran in the truck for the past 2 years. The old reliable tune #3 that ran 8.80's made 1381hp 2205ftlbs @84psi boost and made a peak of 5147psi cylinder pressure. This tune is 1850us 20*peak. The tune that he ran his 8.52@161mph made 1447hp 2304ftlbs on 88psi boost at 5,582psi peak cylinder pressure. This was 2275us and 26* peak tune. Great to see the actual data on this beast and can wait to see how the new motor setup will stack up comparatively.
https://www.youtube.com/watch?v=QHjU84o_W8s https://www.youtube.com/watch?v=WWlSl7aECio
12-28-2015, 11:03 AM | #16 |
Here is the dyno graph
8.80 tune made 1381HP 2205TQ 8.52 tune made 1447HP 2304TQ
01-13-2016, 12:00 PM | #17 |
jesus Christ that torque
01-13-2016, 09:01 PM | #18 |
What RPM do you shift?
01-14-2016, 09:02 AM | #19 |
1-2 4100
2-3 4000 go threw the traps at 4500
01-14-2016, 08:36 PM | #20 |
01-14-2016, 09:06 AM | #21 |
We changed a couple things and put it back on the dyno
new # 1489hp 2392ftlbs
01-14-2016, 01:14 PM | #22 |
Holy ****
01-14-2016, 05:06 PM | #23 |
6>8 Plugless........
That is awesome!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-14-2016, 07:54 PM | #24 |
Who said you can't go deep 8's with <700rwhp in a +3,600lb vehicle.. It does show that HP isn't everything..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
01-15-2016, 06:11 PM | #25 |
Ummm...that would be 1400+ horsepower on graph line #694.
