11-03-2015, 04:21 PM | #1 |
Which cross member for a 4L65E
I plan to put in a 4L65E next summer. Which cross member will I need? Also, the truck is a low hump - will the floor have to be cut for this to fit?
11-03-2015, 06:39 PM | #2 |
Re: Which cross member for a 4L65E
11-03-2015, 11:47 PM | #3 |
Ouch - I will check to see if they sell just the transmission cross member without the motor mounts.
11-04-2015, 10:31 AM | #4 |
Can't you just slide the one you have back and redrill the frame?
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
11-04-2015, 10:59 AM | #5 |
If that will work it saves money. Currently I have a manual, but I have an automatic cross member - though I don't know if there are differences in them and if so, I don't know which one I have.
11-04-2015, 04:00 PM | #6 |
I have installed several 700r4's into 71 and 72 chevy trucks. I always just moved the stock auto crossmember back. Not sure on the 4L65e, but I can't imagine it would be too hard. For nearly $500, I would build my own!
11-04-2015, 08:03 PM | #7 |
I used the CPP cross member on mine. I didn't have an auto cross member as I was converting from a 3OTT. It will fit fine with your low hump cab.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
