Old 11-05-2015, 11:39 AM   #1
Shellyarrowsmith
Shellyarrowsmith's Avatar
Angry starter grind after new flexplate installed
I have recently installed new flexplate on my 69 C10 pickup and have had a consistent problem with the starter grinding. Recently I have dropped the tranny to ensure the flexplate is installed correctly, shimmed and unshimmed shimmed again the starter and am completely stumped! The starter seems really tight although running with 2 shims. I wonder if any one has any other insite on what to do next? The starter is a bosch, the engine was pulled on original installation of flexplate.
Shellyarrowsmith is offline   Reply With Quote
Old 11-05-2015, 11:42 AM   #2
geezer#99
geezer#99's Avatar
Re: starter grind after new flexplate installed
Do you have the correct knurled shoulder bolts and a starter brace installed?
geezer#99 is online now   Reply With Quote
Old 11-05-2015, 02:06 PM   #3
Shellyarrowsmith
I used the same ones that came with my truck they are knurled. The original flexplate had 4 broken teeth so replaced it. I can check on specs to see what is required with the starter as the original 4 broken teeth must have been caused by something. If I replace the bolts to get a slightly longer knurled bolt would that help do you think? Thanks for assistance will keep on digging into this issue.
Old 11-05-2015, 02:54 PM   #4
Shellyarrowsmith
Old 11-05-2015, 03:07 PM   #5
WarMonger
WarMonger's Avatar
Does the starter need to be shimmed? Did you check the backlash of the jackshaft when you bolted the flex plate on?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 11-05-2015, 10:31 PM   #6
Shellyarrowsmith
No I didn't check that just mounted the new flexplate on and installed seal in transmission.
