The 60-66 GMC/Pontiac guy....
Dana 60 half ton 6 lug differentials
I have seen a couple of posts on this and wasn't really interested in resurrecting any old threads.
Here's the deal. I'm mainly interested in GMC trucks over the Chevys so when I have a chance to buy a GMC parts truck or driver I usually jump on it. ![]() I've been trying to find information on the 1/2 ton 6 lug Dana 60's that come in the GMC trucks, 63-66... the BOM numbers are different from the mainstream Dana 60's. .. I read on a thread that they are assumed to be rare.. I've bought a couple dozen GMC trucks in the past 6 years and 1 out of 3 have had the 60.. the others are 44's so they arent that rare.. I have 9 of them. ![]() The earliest information I have found is for 1974 dana 60's. Does anyone know of any kind of information on the 63-66 GMC dana 60 6 lug diffs? I need to find bearing and seal parts and no shops in my area have anything for these trucks. ![]() ![]()
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
Re: Dana 60 half ton 6 lug differentials
I know they were semi-floating, unlike the 8-lug. They also were installed beyond '66, maybe as far as '69. I've seen them mostly in 67/68 GMCs but maybe a '69 or two.
I only do 60-66 but mainly 60-63. .. I am surprised to here they went beyond 66
![]() Join Date: Jun 2006
What options were on the truck that had the 60? There had to be some reason unless it was that GM had cores they wanted to use up because they changed their minds and went to the 44 for cost reasons.
I love my GMC's too and try to buy only them if I can.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#5 | |
![]() ![]() LOL
I've got a factory coil-spring Chevy rear for '60-'62 under my Suburban, and found a spare.
THOSE are hen's teeth. I didn't know they made a 6-lug 60 for the GMCs. I'd love to find one for the 4x4 project I'm going to start this winter. A 6-lug 60 in the rear, and 44 up front, with readily-available used and rebuildable Posi units, and 3.42 or even 3.23 gears would be perfect for my needs. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
I'm surprised that AZ shops don't have information. I seem some crazy built trucks from there. I use Adams Driveshaft, Henderson, Nevada. http://www.adamsdriveshaftoffroad.com/
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#8 | |
Parts stores say they don't exist.
#9 | |
I can see, MAYBE, if drums are hard to come by, but ANY time you go from a Dana 60 to a Ford 9-inch (even just parts), you're going backwards. -Brad
One foot in front of the other
![]() Join Date: Aug 2008
You been to this site??
http://6066gmcguy.com/ |
#11 | |
The Dana I am building has huge 35 spline axles and a bullet proof powr-lok 3.54 posi....
Why in the world would I want to change out anything??? I just need seals and axle bearings. .. That's why I am posting this here... ![]() ![]()
#13 | |
![]() Join Date: Mar 2015
There has got to be a bearing out there that matches.
#15 |
I've got a friend in Michigan who has been building rear ends for 4 decades... everything from concours-resto to hard-core rock crawling Dana 60s with custom thick-wall tubes to Funny Car.
Ultimate Driveline (616) 915-6718. He'll be able to hook you up. Tell him Brad Ocock sent you. -Brad (and as a finder's fee, you can sell me one of those 9 other Dana 60 6-lugs!)
#16 |
60-66 Nut
I assume you have tried looking up replacement bearings and seals using the numbers on the originals?
#17 | |
He has a ton of old parts books in his NAPA store.. he's supposed to be calling me today.. I'm going to rebuild 5 of the diffs I have and sit on the others for future projects. BTW.. these dudes are heavy... :-)
#18 |
60-66 Nut
Yeah, you should be able to find replacements using the old numbers. If your guy strikes out, get me the numbers and I'll see if I can find them. I have several sources between here and Spokane.
I'd like to see some pics of these rare 6 lug Dana 60's if you have a chance.
#19 | |
I have a question. How many coil spring Dana60 6-lug or 8-lug rears has anyone seen? I want to put one in a coil sprung chassis and now I'm wondering about the panhard bar situation. The rear I have is leaf spring, so I know I'd have to provide a mount on the housing. What I'm pondering is clearance with the differential cover. I know it can be touchy just clearing an aftermarket cover on a 12-bolt coil rear. I wonder if there were any Dana60 coil rears (6-lug) and if there were (I seem to recall seeing these before) did they have a unique panhard bar? I'm think I'd need to do my own custom thing because I'm dropping it 6" and would be relocating stock mount locations just as the ECE Super bar does
#20 | |
I believe the '63-up all mounted to a boss on the housing, didn't they? I'd try finding a '62 and older rear and grab the bracket off of it. -Brad
#21 | |
That's correct, the pan hard bar on dana 60s was welded to the axle tube. . However, chevy only used the Dana 60 in 3/4 ton applications.. GMC used them in 1/2 ton trucks so 63-66 GMC 6 lug units would all be leaf diffs. Easy to convert to trailing arm. 60-62 trucks used HO-33 and HO-52 diffs 1/2 and 3/4 ton respectively.
#22 | |
60-66 Nut
I have a '72 C20 chassis that is coil spring and has an 8 lug Dana 60. If I remember correctly the panhard bar mount is on the passenger side axle tube. It's been a while since I have looked at it but I can verify that if you like.
I do make trailing arm mounts specifically for the Dana 60. Quote:
#23 |
60-66 Nut
I was mistaken. My '71 Dana 60 has the panhard bar mount in the casting of the center section. It does have a longer stud with a spacer about 2.5-3" long to move the panhard bar out from the diff cover.
#24 |
I have a photo of the numbers on one.. I've been busy with other issues... I'll get a chance to take some pics possibly wed.. I work from before sun up until after sundown. .
#25 |
I have a line on some sealed bearings from currie enterprise
