11-10-2015, 08:30 PM | #1 |
Dash pad
Who are you guys going through to get dash pads? I have an 86. Also. Won't you have to dye an aftermarket pad and of so what is the best brand of dye?
11-10-2015, 09:13 PM | #2 |
Robert Olson Transport
Re: Dash pad
been dealing with a local upholstery shop and hes been installing those plastic dash caps on ,ime. They work well and match interior colors nicely Im not sure of the brand he is using
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
11-10-2015, 09:26 PM | #3 |
Re: Dash pad
Check out dashesdirect.com
You will need to clean it super well and then paint it with vinyl paint.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
11-10-2015, 10:04 PM | #4 |
Re: Dash pad
In the heat of the desert plastic dash caps don't last. They crack up just like the factory dash. I would put the $100 for a plastic cap toward a recovery job by a local upholstery shop.
11-10-2015, 10:17 PM | #5 |
Re: Dash pad
They can fix those pads?
11-10-2015, 11:20 PM | #6 |
Re: Dash pad
I bought one from brothers a few years back and it seems great!
I also saw someone post on here about justdashes.com I emailed them and awaiting their response
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
11-10-2015, 11:26 PM | #7 |
I know the pieces fit
Re: Dash pad
Classic Parts has them for $329. Are the resto parts suppliers getting them from the same source?
11-12-2015, 06:32 PM | #8 |
Re: Dash pad
Pads can be recovered, but they won't look exactly like the original. The problem is that the vinyl around the instrument cluster and ends needs to be stitched or somehow tucked in to lay flat. Unless it could be recovered for about the cost of a plastic cap I would spend the $$$ for a good OEM cap.
11-12-2015, 10:06 PM | #9 |
Re: Dash pad
I bought a new one at classic industries for $250. Just kept it black. Looks ok but boy is it flimsy as hell compared to the oem. They must of used thinner metal in the form. Just installed it so I don't know how it will last.
Andrew 1953 3100 292 T5 1985 K5 Blazer 350 700R4 208 |
11-13-2015, 09:55 AM | #10 |
Re: Dash pad
Saw these, they say they're making their own and that they're not flimsy. Price is a little better but not sure about the quality. Anyone tried them? CHEYENNE PICKUP PARTS dash pad
11-16-2015, 03:14 PM | #11 |
Re: Dash pad
The Brothers website says their pads are built like the original with metal inserts. From the website:
This OEM style reproduction of the original padded dash assembly for the 1981-91 Chevy/GMC trucks. These show quality dash pads are manufactured with high quality vinyl over foam with steel inserts for an original appearance and fit. Sold in black only but can easily be dyed to match your color interior with BROTHERS vinyl dye. Does this have the plastic "frame" but with metal inserts? Has anyone tried one?
Tommy 1 Pt. 3:21 '72 C10 LWB 402 |
11-16-2015, 03:50 PM | #12 |
///Relaxed Atmosphere
Re: Dash pad
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
11-16-2015, 06:31 PM | #13 |
Re: Dash pad
I followed some forums on here and repaired mine. It came out really well, but there are a few things I would have done differently.
1. Knock down the curled up edges of vinyl. A flap disk in an angle grinder worked great. 2. Fill in the really large holes with expanding foam. I filled the center speaker holes because they were essentially gone, and I'm only putting in corner speakers. In this step, you want to make sure you cut the foam down below the surface of the surrounding vinyl. I also glued in some perforated aluminum for more robust speaker grills in the corners. 3. Fill all of the imperfections with Padded Dash Filler and sand. Make sure you have a complete layer of padded dash filler over the top of any foam, because foam will absorb the paint differently. 4. Spray with rubberized undercoating, let cure. 5. Spray with SEM Color Coat. |
11-16-2015, 07:26 PM | #14 |
Re: Dash pad
Where did you get this material? |
11-16-2015, 10:19 PM | #15 |
Re: Dash pad
It's made by Urethane Supply Company. Plenty of places sell it online, I can't remember which website I bought it from. Whichever one had the lowest price, I couldn't find it locally.
11-16-2015, 10:28 PM | #16 |
Re: Dash pad
Also, just a disclaimer here, my truck is still in body shop jail, so I can't speak to long term durability. I picked at a few hidden edges and nothing peeled off, but I haven't actually had it in the truck. As you can see in the pictures, it is holding up quite well in the basement bedroom between the extra mattress pad and the spare pack'n'play.....
11-17-2015, 10:40 AM | #17 |
Re: Dash pad
I believe most of the replacement dashes will last much longer than the OEM's. Because we will be taking better care of them. When our truck where new nobody thought of the dash cracking and falling apart after a few years in the sun. I know my truck will not sit out in the Florida sun with the dash not covered. And when at home the truck will always be under cover, garage or carport.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
11-17-2015, 11:09 AM | #18 | |
Re: Dash pad
11-23-2015, 04:08 PM | #19 |
Re: Dash pad
I saw an 83 K5 parked in the neighborhood with a recovered dash. It looks like two pieces stitched together except around the instrument cluster. It has some sort of nylon mesh over the defroster ducts and just cut out vinyl around the VIN hole (I think it could be done neater in those areas.) I could not get good pics of the front edge due to windshield glare. I think the concept is good though. It looked like about 1/8" thick white foam under the vinyl.
I wonder if it would be better to strip off all of the factory foam and vinyl and start over with just glued down foam and vinyl. |
11-23-2015, 04:28 PM | #20 |
Re: Dash pad
I don't mind trying one of the reproductions as long as it's vinyl over foam like the original, the urethane pads seem to get universally poor reviews. But I don't think I've seen a consensus on the best place to buy one. For that matter, the resellers may be getting them from the same place. I'm going to try the one 1970pelle has that I linked from ebay, in my military Blazer it'll be hard to hate any flaws or variations from OEM it may have.
11-23-2015, 04:23 PM | #21 |
Re: Dash pad
So I checked with my Dad, he works for a GM parts distributor, and we ran a part number search for the 81-91 dashpad. None left in GM's parts system. Looks like someone had that idea before me. Sorry guys no more $500 NOS dashpads.
11-30-2015, 12:01 PM | #22 |
Happy to be here
Re: Dash pad
Take a look at what Capt Kaos offers- 73-87chevytrucks.com
12-01-2015, 12:34 PM | #23 | |
Re: Dash pad
I realize it won't be as nice as a new complete dash. I'm looking for "acceptable". My 83 is a beater, and I want it to be decent, not a show truck. |
11-30-2015, 01:17 PM | #24 |
Re: Dash pad
Thank you for the link sir!
11-30-2015, 01:26 PM | #25 |
Re: Dash pad
My truck had a thin plastic cap when I bought it. It bows big-time in the summer, to the point that's it's now cracked in the center next to the windshield.
There was a thread showing how to rebuild a stock dash pad on this or another square body forum earlier this year. I need to find it, because the job turned out pretty good. I'm not picky about any stitching, and I'm not sure my Custom Deluxe base truck even had it.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
