09-16-2003, 12:57 AM | #1 |
Chevy 427 BB
I came across an ad for a used Chevy big block 427 engine that ran when it was pulled. Does anyone know how to tell the difference between a "Truck" motor and the "Passenger" motor. I'm hoping that its a passenger car motor but I'm not sure of how to tell the difference between the two. Any ideas on prices.
Thanks, Josh
72Chevy swb 4x4 71GMC swb 2x4 |
09-16-2003, 02:18 AM | #2 |
My other Love
best way is to get the vin, also measure the shaft of the distrubutor shaft length, it will be longer on a tall deck motor as opposed to a regular engine
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
09-16-2003, 09:18 AM | #3 |
Depending on the year, it might have a dual thermostat if it's a tall deck. Two thermostats under one waterneck.
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
09-16-2003, 02:25 PM | #4 |
Wiseass secured himself a BAN
Get the block number and look it up on www.mortec.com
09-16-2003, 06:15 PM | #5 |
Thanks guys,
I'll see if I can get the block number. Josh
09-16-2003, 07:34 PM | #6 |
I thought that all 427's were car engines?
09-16-2003, 07:38 PM | #7 |
my dad has a 427 in his 5ton freight truck and he was telling me the oil pans are bigger on the truck motors.
is this true? |
09-16-2003, 08:48 PM | #8 |
There are two blocks....and I would definitely get the numbers and run against mortec...they do show 366 and 427 tall deck wich is 10.2".
Good luck...let us know what you find.
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
09-16-2003, 11:07 PM | #9 |
its all about the +6 inches
I have a question that may make figuring it out real easy.
Are the distributors interchaingable between a small block and a big block? I think i read that they are, but I want verification from you guys. If they do interchainge, then grab an extra one and see if it'll fit. (the tall deck is...well, taller.) |
09-16-2003, 11:12 PM | #10 |
09-16-2003, 11:14 PM | #11 |
Recovering 67-72 Addict
Yes. small block and short deck big blocks can share a distributor. Only possible differences would be springs.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
09-16-2003, 11:33 PM | #12 |
So bring a spare dist allong with you and see if it fits.
I waould stay away myself if it is a tall deck. |
09-17-2003, 12:54 AM | #13 | |
I got the #'s printed out from MORTEC that list both the tall decks & the short decks. I'm hoping that when I see the block numbers it'll be a short deck.
Hey miket, thanks for the link to the sight. Interesting to know that the industry is starting to build Hi performance items for the higher production number tall deck blocks. Quote from "HOTRODDERS BULLETIN BOARD" Quote:
Josh
09-17-2003, 10:03 AM | #14 |
COME ON YOU GUYS ...... I DIDN'T REPLY TO THIS THREAD AT FIRST BECAUSE I THOUGHT FOR SURE SOMEONE WOULD COME UP WITH AN ANSWER PRETTY QUICK.
THE MAIN DIFFERENCE BETWEEN A REGULAR CAR BBC & A TALL DECK TRUCK MOTOR IS THE DECK HEIGHT. FROM THE CENTER LINE OF THE CRANK TO THE DECK IS 9.8" ON A STANDARD 427 , AS COMPARED TO 10.2" ON A 366 OR 427 TRUCK MOTOR (TALL DECK). IT'S EASY ENOUGH TO TAKE A SCALE, RULER OR MEASURING TAPE & MEASURE IT.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
09-18-2003, 12:11 AM | #15 |
Doesn't the car/lt.truck block say "HI PERF PASS" on it?
09-18-2003, 08:46 PM | #16 |
Update
Well..... I was hoping. It's a truck block. The guy pulled it out of a 74' Heavy duty potato truck. Oh well.
Thanks for all of the input guys, Josh
09-18-2003, 08:50 PM | #17 |
ummm...if its not a truck block...and ofcourse if you done want it...I might be able to use it....of course I would be doing you a favor(J/K)
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
09-18-2003, 08:59 PM | #18 | |
09-19-2003, 10:17 AM | #19 | |
Re: Update
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
