Old 11-14-2015, 01:04 PM   #1
63frankintruck
front and rear suspension conversion questions (kit)
I'm looking to add disk and drop spindles to my 63 c10.
Can anyone recommend a kit that will keep me from runnning into a ton of head aches. (I thinking a kit would be less hassle than junk yarding front suspension and then having to purchase drop spindles anyway)
I found this
Amazon.com: McGaughys C-10 13" Front Big... Amazon.com: McGaughys C-10 13" Front Big...
I'm also concerned I'm going to run into wheel fitment problems. Would also like to use 5 on 4.75 for better availability of wheel choices.
Also, are there axles available for our 12 bolt truck rearends with 5 on 4.75?
63frankintruck is offline   Reply With Quote
Old 11-15-2015, 04:42 AM   #2
andrewmp6
Re: front and rear suspension conversion questions (kit)
Honestly i would go with http://www.earlyclassic.com/ they have everything you need.And i would skip the 5x4.75 bolt pattern the 5x5 is better to me unless the rims you want only come in the smaller lug pattern.
Old 11-15-2015, 08:32 AM   #3
63frankintruck
thanks for the input. can you explain why you think 5 x 5 pattern is better?
Just curious, and would like to find out the pros and cons before having to do this over again at later date.
thanks again!
Old 11-17-2015, 09:31 PM   #4
63frankintruck
I looked at this kit, (appears that it does Not come with a vacuum booster)
Is there a kit out there that comes with drop spindles and everything you need to convert to disk on front?
If so, is there a preferred vendor here? Discounts?
Old 11-15-2015, 09:01 AM   #5
andrewmp6
5x4.75 is a car bolt pattern never used on a truck stock,While the 5x5 is a stock common truck bolt pattern.To have the rear axles and drums changed to a 5x4.75 would take a shop to redrill them or custom order them.But if you go 5x5 both will be off the shelf parts you can order almost anywhere.Have you looked at rims in both bolt patterns?
Old 11-15-2015, 09:30 AM   #6
63frankintruck
No I have not looked rim bolt patterns yet. I do however plan to rebuild the rear end in the truck. And will probably switch out axles. that is why I was asking about the different bolt patterns. I was just under the assumption that five on four and three-quarter it would be more readily available in a rim size.
Old 11-18-2015, 01:07 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by 63frankintruck View Post
... I was just under the assumption that five on four and three-quarter it would be more readily available in a rim size.
There is no shortage of rims available in the 5x5 pattern. You can use any of the 71-87 truck rims that were offered from the factory. If you want aftermarket, there are a gazillion sizes and styles available.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-27-2015, 11:14 AM   #8
63frankintruck
ok, so very close now. trying to deside to go with POL or CPP
http://www.classicperform.com/Store/...6370SWBK5S.htm
https://www.performanceonline.com/Di...r-5-and-6-lug/
POL has more complete set
CPP claims to have "modular drop spindles" that are designed for better fender clearance/stock spindle location
Anyone out there know about this modular drop spindle or has anyone had clearance issues with the POL set up?
Thanks- hoping to pull the trigger today and put this behind me...........
Old 11-27-2015, 04:24 PM   #9
63frankintruck
anyone know about the fender clearance on the POL kit?
Old 11-15-2015, 10:53 PM   #10
andrewmp6
If you just want oem rims stick with 5x5,If you want something different i would pick out my wheels first since some are made in one bolt pattern and some are made in both.
Old 11-16-2015, 12:27 AM   #11
63frankintruck
I think I remember reading somewhere here that you can go with ealry model 90's impala rims
Old 11-16-2015, 12:37 AM   #12
andrewmp6
Those are 5x5
Old 11-17-2015, 11:02 PM   #13
andrewmp6
They do have a power brake booster its just not part of the kit.
Old 11-18-2015, 09:53 AM   #14
68Stepbed
68Stepbed's Avatar
You're getting good advice. The only company I know of that may offer a booster/MC with a drop kit is Custom Performance Products. However, my previous experiences with them have not been all that great. Lackluster products and horrible customer service. Early Classic Enterprises(ECE) has high quality products, and great customer service. Also, any kits I've ordered include everything I needed to install them. There were no trips to the parts store or hardware store to pick up stuff that was left out.
As for a booster/MC combo, check out www.performanceonline.com They sell a pretty slick bolt on setup.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-28-2015, 09:36 PM   #15
63frankintruck
Just thought I would let yall know I ordered this kit yesterday.!Thanks for the advise and feed back (now I will have to figure out what size wheels will work well with my set up)
Old 11-29-2015, 04:19 AM   #16
andrewmp6
You could grab a set of wheels off a 73-87 from the junkyard as a temp set so you can drive it.A video that might help you out https://www.youtube.com/watch?v=-Ib9DXD2sBo#t=80 the tool he uses is like 80 bucks summit racing,jegs anywhere online really.
