Old 11-14-2015, 07:06 PM   #1
hemi43
hemi43's Avatar
Where can i get assembly pictures?
Even though I took lots of pictures, I'm having difficulty remembering where and how every item goes. Right now I'm using an LMC catalog which is a big help, but is not detailed enough. I've noticed a few members here posting pictures of assembly views, and wondered if these were available online somewhere. Right now, I'm trying to figure out exactly how the steering column attaches to the dash panel right below the instrument cluster.
I should have taken a video of the entire truck before dis-assembly.
hemi43 is offline   Reply With Quote
Old 11-14-2015, 08:01 PM   #2
Ewr101
Ewr101's Avatar
Re: Where can i get assembly pictures?
IIRC, there's a "half-moon" bracket that clamps the column to the dash framework with two bolts on either side. Then, at least on mine, there's a plate that covers that with four bolts. Slightly closer to the driver, there's a smaller bracket that screws into the bottom lip of the dash with two large Phillips head screws. Hope that helps.
72 Chevy 2WD Blazer
Ewr101 is offline   Reply With Quote
Old 11-14-2015, 08:12 PM   #3
grillzy
You are welcome to come down and take a video of mine for reference.
grillzy is offline   Reply With Quote
Old 11-14-2015, 08:25 PM   #4
hemi43
hemi43's Avatar
Thanks !! I didn't have the brake pedal assembly in place and that's what threw me in a loop. All makes sense now !! I'm sure something else will stump me soon enough.
Old 11-15-2015, 12:03 AM   #5
jaros44sr
jaros44sr's Avatar
you've got the board at your finger tips, more helpful guys I have never met. But, if that fails you can reference the factory assembly manual, it just isn't played out in a user friendly format
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-15-2015, 03:46 PM   #6
1tuff71
1tuff71's Avatar
2x on the factory assembly manual. As much of a PITA it is to use it has saved me many headaches. Best $35 I ever spent. Mine has about 200 sticky notes hanging out of it. Makes looking "it" up later on less painful. LOL
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........
1tuff71 is offline   Reply With Quote
Old 11-16-2015, 09:31 AM   #7
jaros44sr
jaros44sr's Avatar
Should be in here somewhere,LMKWIN_20151115_105236 by [url=https://www.flickr.com/photos/97391199@N06/]
SAFETY FIRST
AS usual, off topic
Jim
Old 11-16-2015, 10:00 AM   #8
hemi43
hemi43's Avatar
Thanks !! I'll pick up an assembly manual from Bill's trucks.
Old 11-17-2015, 08:22 AM   #9
notsolo
notsolo's Avatar
C shaped strap with 2 bolts holds column,then the column support plate bolts on with 4 bolts has bumper on it for brake pedal, then the trim piece that holds the rubber grommet to the dash bezel. and the wiring goes over and above all that.
notsolo is offline   Reply With Quote
Old 11-18-2015, 09:43 AM   #10
Minnz
Minnz's Avatar
The "half moon" bracket as mentioned above:
72 Ochre Blazer
69 Camaro Z28 Garnet Red
48 Willys (rolled)
Minnz is offline   Reply With Quote
