11-15-2015, 03:56 PM | #1 |
Caliper banjo bolts
Anyone have any luck with getting them at the local auto parts stores? Autozone doesn't have a clue, had to show them a picture. Oreally's has to order them. and is 7/16 x 20 the correct size for the early trucks?
11-15-2015, 05:52 PM | #2 |
Re: Caliper banjo bolts
My '82 K20 uses 10mm bolts. Rebuilt calipers are like 20 bucks, probably best to replace those old ones.
11-15-2015, 06:28 PM | #3 |
11-15-2015, 07:45 PM | #4 |
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you. |
11-17-2015, 01:02 AM | #5 |
God is good!
You can find them in the "Help!" section. Just saw them at Oreilly a few days ago.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
11-17-2015, 09:39 PM | #6 |
Yes, look in the HELP section. Autozone has them there too, no one working there had a clue.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
11-18-2015, 08:17 PM | #7 |
Also Harley Davidson calipers use banjo bolts in 10mm and 12mm. With different style fastener head. Could get you out of a jam.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
11-26-2015, 11:04 AM | #8 |
Found them. For anyone needing to order from the parts guy who has no clue, here is the number
Dorman 13935 7/16 x 20 |
