Old 11-17-2015, 03:30 PM   #1
holli
holli's Avatar
big block 1960
Hi all
for the moment I have a c10 1960 with a 350/th350.
I'll put a big block whit a th400.
it's ok whit the mount engine.
thanks
holli is offline   Reply With Quote
Old 11-17-2015, 03:42 PM   #2
PGSigns
PGSigns's Avatar
Re: big block 1960
You will need to fab up mounts for the big block and move the trans cross member for the turbo 400. It is not a bolt in swap.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-18-2015, 01:21 AM   #3
Captainfab
60-66 Nut
Re: big block 1960
I agree.
Jimmy
Old 11-18-2015, 12:05 AM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
Re: big block 1960
http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Mine was a bolt in but I have a 1965 not a 1960. Had to redrill for the Trans cross member because I used a 700R4 trans. I also cut the firewall so I could use the rear mounting holes instead of the front.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 11-18-2015, 02:09 AM   #5
padresag
Re: big block 1960
if he already has a 350/350 in there he should be set up for mounting
ron
padresag is offline   Reply With Quote
Old 11-19-2015, 12:31 AM   #6
Captainfab
60-66 Nut
Re: big block 1960
A big block needs to either be moved forward from the small block location, or the firewall modified for clearance.
ron
Old 11-19-2015, 01:16 AM   #7
Dans1960SWB
Re: big block 1960
Exactly why I put in a 350. Didn't want to cut the truck up..
Dans1960SWB is offline   Reply With Quote
Old 11-19-2015, 01:39 AM   #8
padresag
Re: big block 1960
but he has the mounting there to do it
ron
Old 11-19-2015, 03:14 PM   #9
Dans1960SWB
Re: big block 1960
Yes he has the mounting but it is in the wrong spot. You would need to move the motor forward like 4 inches so have enough clearance. I will say that in my 60 I have 14 inches from the motor to the radiator. So pleny of room to move it up..
Old 11-25-2015, 12:51 PM   #10
holli
holli's Avatar
Re: big block 1960
thank you for your answer. I had found a motor near home but no answer.
now I search in usa (california so easy for the shipping) a bbc
Old 12-01-2015, 05:00 PM   #11
holli
holli's Avatar
Re: big block 1960
which exhaust do you use on a 1960?
