![]() Join Date: Apr 2006
Carpet
I want to get some carpet for my 72 but I am torn between ACC and Trimparts. What does anyone recommend? Is either UV protected? I don't want fading or discoloration in a year or two. ACC has a think padding that can be installed. Seems nicer for sound and durability.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
![]() Join Date: Jul 2014
Re: Carpet
I have used ACC in my cars and trucks. The quality is good. The Blazer carpet kit fit very well in the front. Some minor trimming in the rear. I'm not sure about fading or discoloration since most of my vehicle are garaged.
Chevy Runs Deep. 1956 210 LS1 TH350 3.31 Posi 12 Bolt 1969 Z/28 5.3 T56 3.73 Posi 12 Bolt 1973 Nova SS 355 TH350 2.73 Posi 12 Bolt 2000 K2500 Suburban LS 6.0 4L80 3.73 G80 2005 K2500HD CCSB LS 6.0 4L80 4.10 G80 2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic |
Re: Carpet
Do you know if it has UV protectant?
Re: Carpet
I don't know. You would have to call. My Nova has had ACC for about 4 years with no fading or discoloration.
Re: Carpet
I think I'll call tomorrow. I read a few posts about fading on the acc carpets but they are old posts.
Re: Carpet
Curious to know as well.
I bought the ACC carpet, but haven't installed it yet. |
Re: Carpet
So I called ACC and Trimparts and ACC told me they have no UV protection. I told them I was concerned about fading and the response was "well not at least for a couple of years". Needless to say that's concerning considering I don't want to replace my carpet in two years due to color change especially if you get stripes or some other weird issues related to how the sun sits on the vehicle.
Trim parts was much better in their response. Not only did the tell me it has a UV treatment they told me several employees have black carpet in their convertibles and have had no color change. They said the only time they have ever had a color change was a red carpet about 6 or 7 years ago. They assured me that black was a color that will last. I know there is no sure way to protect color from the sun but at least the UV protection is there for insurance. Another question I asked is who makes their carpet. The rep at Trim Parts told me their carpet is manufactured in house and ACC is a completely separate company. I have read on other posts people thought ACC produces their carpet. This is not true. Just wanted to clear that confusion up if anyone is wondering. I am still considering ACC as I do garage my blazer and I like the mass backing offered by ACC. Summit sells trim parts carpet for 308.97 and Rock Auto has ACC with the mass backing for 363.41 with shipping. I think it comes down to how much sun it will see and I know mine wont see much. Trim Parts is the only carpet licensed by GM. Part number for trim parts is 53025-501 in black.
Re: Carpet
I went without the mass backing. The front section comes with the factory style jute padding. ACC carpet has always fit very well in every vehicle I have used it in. My cars and trucks do spend a fair amount of time outside and I haven't noticed. ACC also stands up well to heavy use.
Re: Carpet
Do you think the backing would be a good option or not needed? I do prefer a quite interior and my truck is loud right now with no carpet.
#10 | |
Re: Carpet
The padding that comes with carpeting from ACC will feel nice, but will hold moisture, and as you know Blazers leak like a sieve. I would put the carpet directly over the Peel&Seal. Dan |
#11 | |
Re: Carpet
Is this what you use?
![]() Quote:
Re: Carpet
![]() Join Date: May 2005
Re: Carpet
What did you decide on??
Re: Carpet
Hmm I may have to just get trim parts then and go with the peak and seal. Where do you get the peak and seal? Hardware store or online?
#15 |
Re: Carpet
I run everything pretty much how the factory let it go. The noise in mine isn't much different with or without carpet. I undercoat the floors in all my vehicles so if the carpet does get wet moisture isn't an issue.
#16 |
Re: Carpet
I haven't ordered either yet I just bought a set of new foam for the front buckets and I'm trying to source some white door panels. I am going back to the highlander interior so that will be another 1100. Ill probably get the carpet pretty soon though. Ill update as soon as I get it but I'm thinking trim parts just because of the UV treatment.
#17 |
Re: Carpet
I have had an ACC carpet kit in my Blazer for many years (custom sandalwood color) and have not seen any fading yet. Fit and quality is very good. If you are concerne with UV protection, you could just treat it with one of the many off the shelf UV protectants.
#18 |
Re: Carpet
I ordered the ACC from rock auto. About 363 with shipping and mass backing. No one had it that cheap. Summit racing wanted 713 for it and so does ACC.
#19 |
Re: Carpet
I got my ACC Med Blue carpet from Ebay for $280 shipped. Looks great, getting my Jimmy back together hopefully in the next 3 weeks or so. The ACC carpet looks just like the original that I took out minus really faded. Also ordered the matching floor mats.
Ryan |
#20 |
I'm trying....
![]() Join Date: Oct 2013
Re: Carpet
I was advised by people I trust to go with ACC because of fit. Unfortunately this was after I'd had a TrimParts set laid out (de-wrinkling) in my basement for a couple of months. Indeed, I was unhappy with the fit...but the customer service at TrimParts was fantastic. At their suggestion, I made a pattern and they did a custom cut for me which was perfect. They even turned it around in 3 days because at the time we were scrambling for a show deadline.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#21 |
Re: Carpet
I haven't removed mine from the box yet, but will try to make some progress soon and update what I think.
