Gmc vs Chevy grills and lights
Who else likes the gmc grill vs the Chevy grill. I've looked around to see if anyone else has written up a how to. Long story short nothings out there or I didn't look enough lol. My question is how hard or how simple is it to replace Chevy grill and lights to a GM setup. If anyone knows of a thread started with this information and can lead me in the right direction please and thank you
Re: Gmc vs Chevy grills and lights
I did the opposite. I put a modded Chevy grill in my GMC. the holes in the front panel are different for the grill, the headlamp buckets and the headlamp harness is different. the top two bolt locations are the same, I put a bolt in those holes, and marked and drill new for the other two.
So if I just get a complete gmc grill with light and all, make new mounting holes and fab up the harness . or is it not that easy
Yup. I ran my lights off a relay so I built my own harness.
Posted via Mobile Device |
What type of relays did ya use for the lights.....
I used some generic automotive mini relays I had left over. I'm a Tech at a dealership, so I always have some extras.
![]() Join Date: Jan 2011
It is a pretty easy swap. If you do the relay upgrade you can put new style lamps in and have the power to drive them. I have a GMC grill for my 65 and adding the holes was easy. The grill surround was marked using the grill and I found it was also dimpled from the factory in those spots. Should be a few threads in the FAQ section on the relay upgrade.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Thanks I too read the relay post and that's what started my want to swap it out. I was stuck not knowing if i was going to be able to have working lights at first but nownibcan start looking for some parts and get it done.
