Old 11-22-2015, 04:13 PM   #1
68Timber
I know the pieces fit
68Timber's Avatar
Heater blower motor resistor question
My fan only works in the high position, so I was told it had to be the resistor. I took it out and it was corroded badly but not broken so I cleaned it up and checked continuity. It tested good between all poles so I put it back in. Still no joy. Then looking at the plug I noticed I'm missing a wire. What goes here - ground maybe? There is a corresponding pole on the resistor but I don't have a wire in that spot.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-24-2015, 11:36 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Heater blower motor resistor question
my 79 has other colours
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 11-24-2015, 12:10 PM   #3
68Timber
68Timber's Avatar
This is on my CUCV, so that may account for the color differences. You have the heavy duty resistor too, and have a wire in that spot of the plug. Looking at the back-side of the resistor, I don't see how it can work without one, but I posted the same pic and question on Steel Soldiers and another guy said his didn't have a wire there either. Thanks John. I'm going to try a new resistor and see if that fixes it.
John
74 Honda Z50 build
Old 11-24-2015, 12:40 PM   #4
Matt Man
Matt Man's Avatar
Mine doesn't work on the lowest setting. I will follow along.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 11-24-2015, 06:07 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
just thinking some fans are wired to be on low all the time,no off
I cut the brown wire at the speed switch,in both the 78 (fan 3 speed) and 79(fan 4 speed),
to have low as an "off",
maybe someone else had another idea to stop the fan?...pull out the wire?
John
Old 11-24-2015, 08:36 PM   #6
hatzie
Moderator
hatzie's Avatar
The CUCV electrical is similar to the civilian trucks but not the same...
You really need to download the DOD CUCV TMs from Steel Soldiers and the GM CUCV parts and illustration catalog.
http://www.steelsoldiers.com/....CUCV-TMs
52D_1984_87_CUCV_Parts_and_Illustration_Catalog.pdf
Double Orange wire is from HI switch and out to the fan. This one works.
Yellow is low.
Light Blue is Medium. This is Orange with a stripe faded to pink in your picture...
Are you getting 12v on the yellow wire with the fan on Low and the Ignition switched on?
Move the switch to Medium and check the LT Blue wire.
No volts= bad fan switch or wire.
Volts=bad resistor.
The CUCV GM parts book is in the manuals link or you can use the DOD parts manual TM92320-289-20P
The CUCV resistor is GM # 500890
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-24-2015, 09:24 PM   #7
68Timber
68Timber's Avatar
Thank you sir. I'll check those for voltage. I have those manuals and had looked but could not find it. I was looking in the -20, I'm not sure if I have the -20P.
John
74 Honda Z50 build
Old 11-24-2015, 09:41 PM   #8
hatzie
Moderator
hatzie's Avatar
You need the translation from Army TM nomenclature to what's actually in them...
TM9-2320-289-20P is the UNIT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LISTS (parts book)
TM9-2320-289-20 is the UNIT MAINTENANCE MANUAL (Service Manual) I got the wiring diagram from this one.
Understanding Army Manual Numbers
Old 12-16-2015, 05:27 PM   #9
wilkin250r
wilkin250r's Avatar
I've had similar problems on multiple cars. The first time I encountered this problem, yes, it was the resistor pack. However, on my current squarebody the symptoms were the exact same but the problem was the contacts within the blower switch.
I was able to take the switch apart and clean the contacts, but with little clips and tiny springs, it's not a task for those with a faint heart (or poor eyesight )
Exact same symptoms, different problem. Just another reference for people searching this thread in the future.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 12-16-2015, 05:38 PM   #10
68Timber
68Timber's Avatar
And it's also worth noting that you can remove the switch only from the housing and replace just it, if you have one or can find one in the junk yard. A repop from LMC was $79, I wanted to try one.
John
74 Honda Z50 build
Old 12-16-2015, 06:50 PM   #11
68Timber
68Timber's Avatar
Well, I got the LMC heater controls hooked up. The temp and vent controls don't feel so good with a cable hooked to them. Flimsy. Does not feel like it will last. That's speculation though, and I won't ever know. It's going back. The fan switch is bad out of the box. I hooked up the old one to be sure. Oh well. It's not like the post office is crowded this week. Fudge.
John
74 Honda Z50 build
Old 12-16-2015, 07:54 PM   #12
tucsonjwt
My symptom was intermittent no power at the fan switch for several years of fiddling with it. I finally got an LMC heater control assembly and it still did not fix the problem. I could wiggle the connector at the fan switch and it would work. The solution was to get a new short harness and connector to the heater control. I think you can find this harness in the AC Delco pigtail/harness catalog online. You might also find an AC Delco heater control online from the OEM suppliers - most likely cheaper than LMC.
When I was in college I worked for one summer in the Chevy parts plant that made these heater controls. One guy had a full time job fixing these things so the heater control levers would work - if they worked smoothly coming off the assembly line it was an exception. These were far from precision made components.
tucsonjwt is offline   Reply With Quote
Old 12-16-2015, 09:03 PM   #13
68Timber
68Timber's Avatar
Yeah, apparently they get hot inside the pigtail and melt at the connection and you can still buy the pigtail or the switch separately. I haven't been able to find the whole assembly anywhere but LMC. Out of the box, it seemed nice. The levers moved smoothly with positive detents. But once a little bit of tension was on them, they were crap. And I made sure not to hook those cables up in a twist, they were just like they came off. Oh well. I'll see if someone here has one. If you know of a supplier for AC Delco replacements I'd appreciate it.
John
74 Honda Z50 build
Old 12-16-2015, 07:44 PM   #14
wilkin250r
wilkin250r's Avatar
Good info. I was thinking about trying the LMC repop, but if it feels flimsy, I think I'll just stick with reconditioned original.
Old 12-17-2015, 09:54 PM   #15
hatzie
Moderator
hatzie's Avatar
If the switch is melting... You can use a 5 terminal 40A Mini ISO relay to limit the current through the switch when the blower is set on HI. The civilian AC equipped trucks did that with a proprietary relay.
Terminals;
Coil- 85- Chassis ground.
Coil+ 86- Orange 52A wire from switch HI
COM 30- Power Out to Blower
NC 87a-Orange 52B from resistor pack (Low & Med)
NO 87- 12v battery power through a fusible link (HI)
Old 12-19-2015, 09:59 PM   #16
68Timber
68Timber's Avatar
Terminals;
And mount this on the firewall behind the switch? I've used relays here and there but I still speak 12v haltingly - forgive my ignorance.
John
74 Honda Z50 build
Old 12-19-2015, 10:38 PM   #17
hatzie
Moderator
hatzie's Avatar
Mount it wherever it's out of the way. GM put the AC blower relay on the AC box in the engine bay. Just be sure the terminals are facing down so water will not fill the relay.
Autoshop101 Relays
Old 12-25-2015, 11:53 AM   #18
68Timber
68Timber's Avatar
Autoshop101 Relays
I appreciate the help. From looking at the schematic and comparing it to this:
Terminals;
it's starting to make sense. I think. Except for NO 87- 12v battery power through a fusible link (HI). Is that a wire you need to add, or can that come from the switched hot on the back of the fan speed plug? Whichever one that is, I'm not sure.
John
74 Honda Z50 build
Old 12-25-2015, 01:14 PM   #19
68Timber
68Timber's Avatar
I should have skipped the whole LMC controls and gone this route from the start. The cables clip onto the little control board behind the switch. I couldn't get mine to release, so I forced the issue and tore the tab. Why fight it, right? I have a new one sitting here from LMC. So now, instead of just getting a new switch for my old controls, I need another complete unit. Ebay to the rescue. These are the sellers pics.
John
74 Honda Z50 build
Old 12-25-2015, 03:55 PM   #20
hatzie
Moderator
hatzie's Avatar
Terminals;
That one is a new wire. It offloads the current draw from the Blower switch with the blower on HI. GM did this with the AC trucks. Not sure why they didn't do it with the base Heater trucks.
